RWL-34 Heat Treat Sample #8A:
This one is air quenched while in the foil wrapped packet.
(0.75 X 1.5 X 0.138 inch RWL-34, foil wrapped and placed in cool oven)
Ramp to equalize
1400 F. / soak 10 minutes (see note at bottom area of post)
Ramp to target
1950 F. / soak 25 minutes
Rapid air quench (quenched 'in the packet')
Snap temper immediately (handing temp., guessing at ~> 120 F.): 350 F. / 1 hour
Deep cryo: 17 hr 15 min. (> 12 hours not essential and no added benefit)
Temper after still air warming to room temp.: 550 F. / 2 hours (all tempers, snap included, were 5 to 7 minutes greater than actually specified)
Temper: 550 F. / 2 hours
Rockwell after snap temper: 60 HRc
Rockwell after deep cryo: 63 - 63.5 HRc
Rockwell after first temper: 60 - 60.5 HRc
Rockwell after final temper: 60.5 HRc
Fracture Picture:
http://riflestocks.tripod.com/steelgrain8.html There are both the un-heated oil quench and the air quench on that page.
Note: I could kick myself for doing this but I increased the equalize time by 3 additional minutes for this air quench test. That makes this test more different than the oil quench than just the type of quench used. I knew better but did it anyhow and wish I had not.
Regardless, no test so far has proven as good as test piece #7B (
http://riflestocks.tripod.com/steelgrain7a.html ). That was an oil quench with a defective foil packet, an unnoticed pin hole or something that caused a leak. This is not a solution to finding a proper 'in foil' quench method because an inconsistant quench causes severe stress and varying transformation among the surface areas. A pin hole or a purposefully made slit in the packet will not allow all surface areas to contact quench at the same moment in time.
For me, after all this I am convinced that the steel is best quenched out of the packet and that optimum grain will not consistantly be acheived without doing so. I am also convinced that if quenched while in the packet the difference between pre-heated oil quench and rapid air quench favors the rapid air quench and I would feel more confident air quenching a foil wrapped blade than quenching foil wrapped in oil. As I stand now with what I have seen thus far trying to properly quench a foil wrapped steel is like holding a cat by its tail. There will be a lot of wiggle because of varying atmospeheric insulation. From my experience with this series of testing the aluminum plate quench was disappointing but I must admit that I may have given up on it earlier than I could have however, the same basic theory I have concluded for myself would apply to the plates in that not all surfaces of a tapered and beveled blade will contact the quench media (aluminum).
HOW THE TEST PIECES WERE BROKEN: Early on I used a dremel cut off wheel to score the pieces after heat treat. I soon learned it was much easier and more consistant to use a hacksaw to score the pieces BEFORE heat treat. All pieces were broken while clamped tightly in a vise with the score line upward facing the hammer blow and with the score line against the edge of the vise jaws (score line not hanging away from vise jaws but not hidden by vise jaws). All pieces were scored on one face and the two edges. One deliberate blow of the hammer was used and I strived to keep the head of hammer parallel to the test piece and centered.
In all cases, save none, the better looking parts of the break were always on the underside, the side opposite the hammer contact side.
RL
