Does it strike you that those serration are angled the wrong way? If one is trying to cut strapping, rope, or some other fibrous stuff, isn't a pull cut easier, safer, and stronger than a push cut?
Iron is formed when a star loses its balance between nuclear fusion and gravity, with gravity winning out as the star's fuel is exhausted. Hydrogen burns, becoming helium which collapses and as gravity increases then fusing into carbon and oxygen. As gravitational force increases more, a threshold is reached at which carbon and oxygen begin to fuse into a nickel isotope that is the precursor of iron. Once that threshold is reached, the actual formation of iron takes place in the last 1/1000th of a second of final collapse before the star explodes as a supernova, thereby distributing iron and the other elements across the universe.
So when you wish for a Basic 8, you might say the sacrifice of an ancient star is the first step in the process.
I knew it!!!
But now that the secret behind INFI has been revealed, will not all start making knives out of INFI steel
Will there be enough INFI left for the Basic-8 ?
Will there be enough INFI left for the Basic-8?
Wait till tonight--you can see a lot more after dark. :thumbup:
