- May 3, 2011
Been carrying this one for a good while now, no desire to swap out. I’ll go to a micarta when I do tho
Beautiful dog!
Thank you. Full of energyBeautiful dog!
It's certainly a pretty one. I wonder if it comes in damascus.Im gonna appreciate this one!View attachment 2328130
Lord I hope not!It's certainly a pretty one. I wonder if it comes in damascus.![]()
If there was one thing I would change about the Large Insingo Inkosi to make it an even better EDC and thats a BIG IF, it would be its weight as it is not a light weight knife. I find myself putting a Sebenza in my pocket in shorts or casual trousers.
This CF model completely removes that! Ive alway said if I could only have one knife again it would be the L Insingo Inkosi. I think if I had to pick right now it would be this CF.View attachment 2332529
Sorry Doc, this one is staying!So, you're saying "callings dibs" would be useless? Or do I still have a chance?
Question about the action on a small Inkosi - I only have a Mnandi to compare it to, which opens like a breeze. My new-to-me Inkosi is substantially stiffer. I can do the slow swing open with the thumb stud, and it’s smooth as you’d expect with no hit of grinding whatsoever, but it’s a good bit stiffer than the Mnandi, which I didn’t expect. I loosened the pivot screw a tad, but that didn’t change anything. I’m wondering if it needs to be taken apart and cleaned/lubed, or is that about normal for this knife? It’s. It a big problem - I still love the knife. Just wondering.
Edit: So I went ahead and pulled apart the pivot end, cleaned it up good (lots of black stuff wiped off every surface), dabbed some lube here and there, and reassembled. Took me around 30 minutes, 25 of which was getting the washers perfectly aligned so the female pivot would go all the way through. Talk about tight tolerances! Could just be my feeble brain, but it does feel ever so slightly easier to push open. Not as easy as the Mnandi, but easier than before the disassembly. And everything is still nice and tight. That’s some kinda engineering in this thing.
Apparently the new lube is spreading around, because I swear it’s getting easier the more I fidget with it. That first push is leaving much less of a dent in my thumb, like almost none. I hadn’t thought about stropping the washers - good idear. Anyway, that’s good to know if/when I snag another one. A small Sebenza Insingo with bog oak or ebony inlays has somehow made its way onto my radar. I mean, three is better than two, right??I've had to take apart several new CRK Sebenza and Inkosi to clean, lap the washers on a strop with diamond spray, and reassembled lubed with OCD-4EDC Slickem all grease. Much slicker and easier to flick open action afterwards.
I wouldn't know, I'm up to 9Apparently the new lube is spreading around, because I swear it’s getting easier the more I fidget with it. That first push is leaving much less of a dent in my thumb, like almost none. I hadn’t thought about stropping the washers - good idear. Anyway, that’s good to know if/when I snag another one. A small Sebenza Insingo with bog oak or ebony inlays has somehow made its way onto my radar. I mean, three is better than two, right??![]()
