- Oct 8, 1998
Grind a car key into a blade on a flat rock, or you can use em for fishing lures, and trap parts. Split rings etc..
Heres one for ya....
the plastic rings that hold a six pack together...
I can't imagine having a fresh supply of them with me, in my pack so the ones likely found on the ground have deteriorated (brittle) to the point of not being able to be utilized as ties of any kind. SO, perhaps you can tell I have spent far too much time with plastic six pack rings in my youth...I know they are definitely good for one thing even if the UV light has broken them down - FIRE! If you get one going, it will drip molten plastic onto damp kindling/fuel and help to get it going. I've burned so many of these things in my youth...
If you did have a fresh one that wasn't brittle, you could use it the same way you would cheap rope, shelter construction, etc.
Next Item: A busted CB Radio, six feet of coaxial cable and a steel whip antenna - you CANNOT fix the radio.
