Does anyone make a Pemberton sized pocket sheath?
I just received a pair of GEC small pocket slips. The leather is much thicker and coarser than I would like, but, it does fit a Pemberton, and they are very inexpensive. You could trim down the top flaps too.
Pictured next to the Deerskin slip I made for myself. The GEC slip weighs 14 grams, the deerskin one weighs 3 grams. The GEC slip is loose enough that the Pemberton will slip out if you hold the slip upside down. That can not happen with the more closely fitted softer deerskin.
I recommend looking for some thin split cowhide at Tandy leather, especially if you own a sewing machine.. The one I gave Arizonaranchman was made by a friend at an automotive upholstery shop, where they have such leather already, as well as industrial grade sewing machines.
fwiw, the GEC small knife slip also fits a 2 blade Charlow
I dont like the GEC because its mouth stays open, so its not likely I would put it in a pocket with keys and change. I wish GEC had used a softer leather, so the flaps might close over the mouth, keeping keys and change from touching the knife.
You can see here how my 2 blade Sheepfoot Charlow fits in a way that holds the flaps open (the Pemberton does not have that issue):
You can see the 3.5 Barlow sticks up past the end of the stiching
fwiw, GEC also makes a slightly larger pocket slip I have not tried, that might be a better height match for the Barlow.
