Allan Molstad
Banned
- Feb 1, 2007
What a joke....
I'm not at all sure what to think of my last flex/bend test on a 52100 ball bearing knife I just did.
The blade snapped at around 60 foot LBS of torque.
I will try to post some photos, (There will be no video of this test posted on line) that show the snapped blade.
The grain along the break appears small to the eye, I dont have a scope to look closer, but I dont see any monster grains.
I guess I should back-up and tell you what I did to this blade and ask for your thoughts and advice for next time.
The blade steel came from a 1&1/2 inch ball bearing.
the cutting area of the blade is about 4 inches long, with a 3/4 inch Racaso and a 3 inch tang.
The blade is/was about a little over an inch wide at the widest part, and right around a 1/4 thick for much of the spine.
The shape is like a Ed Fowler "Pronghorn"
HEAT TREATMENT?
Becacause of all the heat I took after my last flex test I decided to change things up and do a different type of Heat treatment other than my normal O/A torch and edge quench.
1 - This Time, I clay-coated the areas of the spine and sides and tang that I wanted to keep from getting too hard.
2 - I heated the Texaco type "A" quench oil to 160
3 - I placed the "whole knife" (tang and all) in the hot running forge and heated until it was nonmagnetic.
4 - I kept the blade at this temp for about 2 min, while I got a few things ready in the quench tank
5 - I dunked the whole blade in the oil, and moved it around under the oil to help speed the quench cooling.
6 - When blade was still very warm, I placed in a warmed kitchen oven set at 400 temp, for 2 hours.
7 - took out of oven and cooled outside in the winter cold
8 - did another temper in Kitchen oven for about 2 & 1/2 hours at 400 temp.
cooled in freezer over night.
The knife was finished to 400 grit, then buffed to a mirror finish.
However I decided I didn't like the final design and so I wanted to test it to see what if any advantages are found in this new HT
Blade was placed in a vise as shown in the new DVD by Fowler.
I used a torque wrench to keep track of the force needed to flex the blade.
The Flex/Bend test?
I bent the knife a little at first and went to 20 foot LBS,
The blade returned to straight and true
I bent a little more next time, took it to 40 foot lbs,
Again the blade returned to straight and true.
I looked very close at the blade and there was no sign that I had troqued on the blade at all.
next I went to 50 ft lbs
Again no change at all, blade returned to straight and true
60 ft lbs,I admit didnt get a good look here, but I sure didnt notice any difference
65 ft lbs and the blade snapped...
Actually I never reached 65 lbs, I was going to go that high but it snapped at some point as I pulled on the wrench.
RESULTS?
I concider this concept of heat Treating an error,,,a clear error and something I will not do again.
HEAT TREATMENT?
The Flex/Bend test?
RESULTS?
