I would like some clarifications, as some of this does not seem to add up. What is this "bending vise" you mentioned, how exactly do you get your readings? It seems to me that the numbers you are getting are not directly related to the steel strength, proportional perhaps.
One of the things I have to ask is the 60 ft/lbs of torque, if you were to drive that knife into a wood block/tree 1", and stand on the guard 3" away, it would require 240 lbs to flex it to the same point. (240lb* 1/4ft= 60 ft/lb) personally, that is twice what I weigh. a similar piece(exact same shape) that was only hardened halfway back would probably "give" and begin to bend instead of flex at my weight. So, I guess if you are using a bent to tell you that you are abusing a blade you then can stop before it breaks. Please realize though, once a blade bends, it is damaged goods, it will weaken with each bend. as long as a blade is just flexing, it will retain it's strength.
You mentioned that a 1/2" wrench pulling out a truck? I would use a crowbar myself, not a knife. a crowbar or a wrench has a different cross section than a knife. when you are stressing a piece of steel, a 1/2" square bar has 2x more strength than a 1/4" x 1" bar flexing along the 1/4" side, but only 1/2 the strength of a 1/4" x 1" flexing along the 1" side even though all three bars have the same amount of steel in them. Prybars and wrenches are round to handle the stresses they need to take.
May I also remind you that the torque wrench that you are using is a thoroughly hardened and tempered piece of steel? as you are taking your readings, the wrench is moving through it's elastic range, it is still flexing, it is not breaking, nor is it bending(at which point it would be useless for taking readings anymore)
I am glad that you are testing to make sure that you are producing a good product. I think we all should. But please make sure that you are not trying to test two or more things at a time, it may cloud your results. and please try to compare apples to apples, not oranges. Make sure what the results you are testing mean, and then make a comparison with a similar product, and test.
Ken Nelson
