I only drill in with the drill bit to establish the size (1/8") hole then use an end mill. Doing it this way I don't have to put the scales in a vise. My folders taper from one end to the other and using a vise is problematic once the taper is ground in.Do you find that using an endmill to establish your holes after they have been started with a normal drill works well
Thanks.Not a knife maker but I just wanted to say the design looks awesome, and I will be following to see the end result!
makes sense, do you find the bottom is flat enough? what type of end mill do you use? I assume its a square cut end mill. So far this seems to be the way to go.I only drill in with the drill bit to establish the size (1/8") hole then use an end mill. Doing it this way I don't have to put the scales in a vise. My folders taper from one end to the other and using a vise is problematic once the taper is ground in.
here is the latest revision of the design. I changed the stop pin to a .125 internal (still shouldered). I added a backspacer that serves to set the distance between the 2 scales. The stop pin is located via 2 .125 threaded barrels. the barrels will go all the way through the frame to make drilling easier. the barrels are held in via titanium screws. This allows for the backspacer to be made of any material (carbon fiber, titanium, g10 etc.). It also allows for a totally enclosed lanyard hole to prevent the cord from fraying. The pins pass through the scales and the backspacer so lateral rigidity and locating function is retained. I think this will make for a better knife that is easier to machine. I'm open to any and all suggestions regarding the design.
Ill reply to this quote for all the other comments you replied to my posts for:
First you questioned about floating pins vs shouldered. Im assuming your sourcing pivots/stop pins from ticonnector since you mentioned ti screws and they're the only ones ive found that offer 1/8" stop pin/pivot barrel with ti screws. You can get spec hardened floating pins from usaknifemaker.com and also alphaknifesupply.com They are hardned to 58-60hrc I believe (the websites say what its hardened to)
In terms of waterjetting to spot holes, really theres no need until your doing many at a time. The price youll pay to have accurate jetting done outweighs the 'accuracy' because it still can be off depending WHO does your waterjet. I had stuff jetted before to spot holes and they were off believe it or not. To assure your getting dead even both sides glue the scales together and centerpunch each hole off your template and drill/ream them together. If you do it that way the holes will always line up perfectly. Now, you can go waterjet, but do you want to pay the cost to have a set jetted, and figure out the design doesn't work?
In terms of tooling/equipment. What do you need a rotary table for? No need for that unless your using that to make your 'counterbores' vs using actual counterbores. Endmills are not perfectly flat at the bottom so you cant just plunge in to create a counterbore, thats where a rotary table will come in. You can do it either way, more use counterbores, but rotary table gives a much much nicer finish.
If you source pins from usaknifemaker or alphaknifesupply you will just spot drill a hole through both scales, or through one and blind hit the next scale. Then when you split the scales apart you will drill in the back with a #31 drill making sure not to blow through the other side, then ream it with a 1/8" reamer and your pin will slide right in and be a floating pin. The only thing I use counterbores for are my 2-56 screws, collars/pivot, and bearing pockets.
littlemachineshop has good mills, they are grizzly/harbor freight mills that have upgrades to them such as dro's and higher powered motors etc. You can get a tramming device on ebay or tooling websites that hold 2 dial indicators, and it fastens into a collet so as it rotates you can see each gauge move independently.
I think that covered all your questions you relayed back that no one has answered. If you havent watched already look up ekim knives on youtube. He has a entire series about building a framelock from design to completion and tells/shows you how to do everything. That will answer 99.9% of your questions id assume. Theres like 25 or something videos each 30+ minutes on it.
Based on the feedback I have received so far it looks like you are right. Floating is likely the way to go. Thanks for your input.Using shouldered stop pins will require you to be dead accurate on the blade thickness and bearing pockets. What that means to me is if I get a little scratch on the ricasso and have to sand it again those measurements change. Using a floating pin allows you to just shorten the stop pin.
I use my rotary table for making the stop pin track only. I use countersinks for bearing and pivot pockets as well as for the 2x56 screws. I also typically use standoffs instead of back spacers. Do watch Ekim's linerlock series. It's very good.
Thanks for your reply,
It sounds like a floating stop pin is the way to go. At least it is shouldered which will provide some lateral rigidity. It is my intention to source the majority of my hardware from ti connector. I like the idea of having a solid stop pin that is spec hardened and recessed into the titanium. If it has to be floating that's ok I have changed my design so a small backspacer sets the distance between the scales. Between this and my pivot that should provide enough support against inward flex. The handle pins that are inside the backspacer, the stop pin, and the pivot should provide plenty of lateral support.
As far as waterjet goes. I have the same fear that it may not be accurate enough. I have used it in the past for slipjoints and it has been good enough for that. There is a place local to my work that has been great. They have a $50 minimum and they are very cost effective. About $5 per knife. They are extremely nice and I want to support their business if possible. If it turns out they are not able to handle framelocks ill look elsewhere or do it manually. I want to give it a try though. If it does work its way easier than manually cutting and profiling.
The rotary table is to account for my internal stop pin. I need it to cut the track. I also like the idea of being able to use it to make pivot collars etc. I also plan to use it to mill the pocket for the lock bar stabilizer. Maybe there is a better way to do all this stuff but I am unaware of it.
If the waterjet doesn't work I will definitely try to glue the scales together and drill all at once.
I will certainly look into little machine shop and the dual dial indicators.
I have watched the ekim knives framelock series probably 10 times. In his video he uses a threaded stop pin but most of the info is exactly what I intend to do. I think I have watched every video he has ever made. I would never have started making knives if it were not for his videos. I was lucky enough to buy a fixed blade from him once and its one of my most cherished knives. I recommend his videos to anyone who will listen to me.
Thanks for taking the time to reply to me. When I finally get all of this sorted out and make a functional framelock it will be because of people like yourself. It is awesome that so many people are willing to share their knowledge. Not many things work like this today.
Sounds like your headed in the right direction. Any material that you can get flat and square is good for a backspacer. You can use standoffs or any of the materials you listed above, plus anything else you could think of. .05-.06 is plenty of web thickness in ti scales. If you think about it you never will have enough lateral force on the blade to pop or bend that web, if you do your using the knife completely wrong and it will fail anyways. All your force will be up and down, front and back, which there will be quite a bit of meat there to support that. I know guys that go down as low as .020" web and have never had a failure.Thanks to all who have replied so far.
Here is a quick update:
I have finished all the electrical in the new shop and tied into my main panel. The entire shop has been painted with fire retardant paint. I have hung a pvc strip freezer style door to separate the grinding room. Just a couple weeks until its ready for action.
I have looked into some mills that are available here in Canada, specifically at busy bee. The craftex cx601 has caught my eye. It is about twice the weight of the g0704 which hopefully translates to a more rigid machine. Also parts/warranty are local to me. The downside is they do not offer a dro variant like the g0759. when the dust settles I would save about $1000 that I could use to get some tooling and a bolt on aftermarket dro. I didn't want to have to mount it up myself but I think it will be worth the hassle. If anyone has any experience with craftex I'm all ears. I did go and check the machine out in person. the floor madel had been dropped so it wasn't in great shape. the y axis was difficult to move. The salesman assured me that a proper unit would not be like that.
I called ti connector with a barrage of questions that were all very politely answered. I will order all my hardware from them once I get everything sorted out. They seem very helpful and accommodating. As far as I'm concerned they have earned my business. I have also started to look into specific handle and blade materials. I have settled on 5/32 blade stock and .154 ti for the handles. when everything is finished the final dimension should be just under .500 total handle thickness.
In order to make the backspacer work I need .200 thick ti at minimum. I plan to source my ti from AKS and they currently do not have any ti that thick. USA knifemaker does but im trying to order from as few places as possible to save on shipping. I was thinking that since my backspacer only serves to set a fixed space I may use CF, G10, or micarta. There will be threaded barrels inside the backspacer so I don't need to tap the material. Any thoughts? the thicker ti is expensive and the synthetic material would shed some weight.
I was hoping to do all my counterbores in the ti so the blade just needs to be flattened again after HT but it looks like my web of material between the bearings and pivot screw would be too thin for my liking (.050 to.060). I will need to counterbore the blade as well. Do you guys c/b pre or post heat treat? I am worried if I set an exact depth pre heat treat that there might be a slight shift during the quench that may throw off my tolerances. my initial thought is to hog out most of the material pre heat treat and set an exact depth after heat treat. Im interested to hear peoples opinions. Will a carbide counterbore be able to leave a nice finish on hardened steel and will it cut efficiently (ish)? for refrence I will be using cpm154 because that's what I'm most familiar with. I plate quench and typically have no visible warping.
My thought are to undersize my stopping track and c/b then machine post HT to exact specs provided the machine and carbide tooling will handle it. the cx601 has a 1.5hp brushless motor and is about 575lbs if that helps at all.
Any help is much appreciated.
I plan to buy enough materials to make 5 to start. I will make them one at a time start to finish. My goal is that by the last one I have the process figured out. I will try to get my mistakes made and solved in that run. It took about 5 knives for me to get my slipjoints figured out. Maybe im being optimistic but only time will tell. Im fairly certain the design will work. I have gone over my CAD a fair bit so far. It will just be a matter of developing consistent repeatable processes and executing them properly. Hopefully im up to the task. All the advice I have recieved online has been super helpful so far.Awesome love to see it all come together! Are you doing a one-off first or a run of them?
Cool, the DRO will be super helpful when drilling your x-y coordinate holes so they will be spot on.I plan to buy enough materials to make 5 to start. I will make them one at a time start to finish. My goal is that by the last one I have the process figured out. I will try to get my mistakes made and solved in that run. It took about 5 knives for me to get my slipjoints figured out. Maybe im being optimistic but only time will tell. Im fairly certain the design will work. I have gone over my CAD a fair bit so far. It will just be a matter of developing consistent repeatable processes and executing them properly. Hopefully im up to the task. All the advice I have recieved online has been super helpful so far.
