No, that is carved Stag-Bone, and dyed.
When they burned the bone, it was dark on the high points and ridges,not the low grooves, alnamvet.
It's what's called a Wharncliffe frame by most. Your knife seems to be a Case 55 pattern,I think,which is a 3 blade Wharncliffe frame whittler,with a straight edged "wharncliffe"(your knife has the blade also called wharncliffe) blade as the primary,as opposed to the curved pruner blades on the farmer jacks..
A farmers jack is in a similar frame,but has a single spring (almost always),using a pruner (hawkbill) blade as primary ;and a spey or modified spey as the secondary blade.If you look closely ,you can see the differences in the primary blades.
Yes, I see the differences in blade types, but the actual pattern/frame are almost the same.
Blade Show,top of my list John,Lord willing. I'll try to post some of the pictures you want,soon.Lyle: Do you have any hole or well shots of these style knives? I know that there are different ways to accomplish the bypassing of the blades by changing plunge lines, offsetting plunge lines, etc. but pictures work better for me than explanations. Eh? How are your Blade plans coming??
John
