The Sharpening Thread
Lennox
Platinum Member
Ok folks let's get to sharpening some Infi. :thumbup: This is just the the first part and it's mostly a redo on stuff i have written before, i have a lot of pics, vids and more sharpening stuff coming up soon.
During my time here i have seen many people ask about sharpening various knifes, i can see why people with no experience in sharpening are hesitant to start messing around with expensive blades due to fear of failure so sending your blade to a pro is often a good solution. Now!! if you want to learn how to do it yourself there is a few ways to go about it. If you want to invest some money in something to help you out you should get a belt grinder and a bench grinder for a buffing wheel and scotchbrite wheel and such ( i will be getting back to this later), if you don't want to get into using machines there is a jungle of other stuff that works and i will try to go trough most of them and explain how they work and how to use them without making things too complicated and nerdy.
Sharpening systems seem to work ok for a lot of people but convex edges like on most Busse's are kinda out of the question on these systems unless you take your edge down to a v edge, i will talk more about v edges later.
DMT sharpeners are nice tools for sharpening and maintaining both convex and v edges but the blade needs to be straight due to the flat surface on the DMT so recurves and blades like the zilla is pretty much out of the question when using flat sharpening tools. When practicing with a DMT you can use a permanent marker to color the part of the edge you want to work on and this way you can easily see what you are doing to the edge, on a v edge you color the v and on a convex edge you color all the way from the cutting part of the edge to where the main edge stops and flattens out towards the spine. If you choose to use DMT's you should get some cheap blades to practice on and after a few days of practice you should be able to master sharpening with DMT's.
[/URL][/IMG]
How to practice you say.... Hmmmm we are getting to that part now.
When i sharpen with the Spyderco stone a DMT or any other stone for that matter i always make sure i start behind the sharp part of the edge (Convex edge), i will try to explain as best i can.
Take look at the convex edge in this pic and imagine that you start sharpening the Apex (cutting part of your edge) first, what you end up with if you do this is a blunter edge angle, do this enough and your edge will be a bitch to get sharp. :( But if you take care of the convex on both sides before touching the apex of the edge the geometry will stay correct and you can move on to joining both of the convex sides by sharpening on one side until you get a burr on the opposite side, then proceed to sharpen on the burred side so you cut/move the burr to the first side you were working on, then you simply remove the burr on a stropp or a fine stone and whooooohoooo you have a razor sharp cutting edge. :D
[/URL][/IMG]
A Japanese water stone is also a great way to sharpen and i will let this video from Carter describe the technique. I have been using Japanese water stones for more than 12 years now and they are well worth learning to use, When you get the hang of using them you can make just about any knife razor sharp in minutes, the best brand i have tried so far is KASUMI, they are expensive but will last you for years. An important thing with water stones is to let them soak in water for about 30 minutes before using them.
[video=youtube;ozZF2EgnYm0]https://www.youtube.com/watch?v=ozZF2EgnYm0[/video]
[/URL][/IMG]
These smaller waterstones are great for recurves and taking care of stuff such as a sharpened svedge due to the rounded butt. when your fine waterstone gets clogged with steel you need to use a rougher waterstone to rub it out (1000 grit is great) Just rub them together with water and they will clean up nicely, this also helps to keep your stones flat.
[/URL][/IMG]
The natural stones below are great stones to use on most knifes but i find them to be a bit slow when used on INFI
[/IMG]
A leather stropp with some stropping compound is a must since this is usually all you need to get your INFI back to shaving sharp after a chopping session, just rub some compound on the leather and stropp away from the blade at a slightly flat angle at first and work your way towards the apex. Why is stropping so great on Infi??????
Well! this is because Infi is extremely resistant to chipping and as a result it deforms instead of chipping, so if your Busse feels a bit dull and won't cut paper or shave after you have been at it killing hordes of those pesky zombie pine trees :D just stropp it with some medium or fine compound and 9 out of 10 times it will go right back to being scary sharp.
[/URL][/IMG]
The spyderco ceramics below are some of the best ceramics you can get, they hold up really well and 9 out of 10 times they are all you will need besides a strop. The thin stick is for folders but it works great in recurves and on smaller blades.
[/URL][/IMG]
A rolled up leather belt with some compond makes for a great stropping tool when you are in the bush, just tie one end to a tree branch, tighten and stropp away.
[/URL][/IMG]
A small belt grinder like this one from Proxon is nifty and cheap little machine for taking care of all types of knifes, i prefer to use a bigger grinder myself but a small one like this works just fine.
[/URL][/IMG]
This way you can make or maintain a convex edge with the Proxon
[/IMG]
Some soft insulating tape from Armaflex with some 400 grit paper on top is also a great way to make or repair a convex edge
[/IMG]
A machine like this one from MOE & CO does the same job the leather stropp does and it takes less skill to use but you dont need one of these unless you are planning to sharpen a lot of knifes often.
[/URL][/IMG]
[/URL][/IMG]
The scotch brite wheel above is a 600 grit wheel and will give you a great satin finish. Keep in mind that the scotch brite wheels will easily catch the spine on your knife and take your finger off if your hand is in the way Be careful!!!!!!!!!!!!!!!!!!!!!
Before scotch bright wheel. (In this pic you can also see a good way to use the marker on your blade.)
[/URL][/IMG]
After scotch brite wheel.
[/URL][/IMG]
A piece of rolled up 1200 gritt paper for wet sanding is a super cheap and very easy way to sharpen your blade and it's amazing how well this works .
[/URL][/IMG]
More to come in the next few days.
Len
I purchased a spyderco sharp maker and a leather block with white and green compound. I want to sharpen my NMSFNO, although I think these 2 sharpening steps will get rid of the convex edge. Is that ok? Or should I learn the mousepad method after the spyderco + strop to get the convex edge back?
Btw on behalf of everyone, thanks for all this sharpening info -- very useful!
Is this thread meant for discussion or just your experience sharpening?
Is it OK to post our own experiences?
Thanks
You should easily be able to keep your convex edge on the sharpmaker. When using the sharpmaker just gradually twist the knife to work the whole primary edge and then go to the stropp, i have tried this and it works just fine :D :thumbup: all it takes is a steady hand.
Thanks
Please post your own experiences :thumbup: there is 1000's of ways to a sharp blade.
Ok here goes.
I am free hander but for kitchen knives and also razors.
Pocket knives are new thing for me, so given the choil construction some knives have I figured I'd grab a Lansky to see how that will work for me.
Works OK for hollow ground blades, but not so much for thick ones, right now waiting on a diamond hone to see if that will speed up the process.
In the mean time got new Manix 2 in S30V, and figured it was time to hot the stones.
Progression used Atoma #120 for reprofile (serious over grind right before the choil).
320 well used DMT to erase the Atoma rough grinding
400 Sigma Power
1k Sigma power hard version
from here I jumped straight on Japnese naturals to see how they will respond to the steel. Sucess!
Edge came out great, nicely convexed and super sharp.
Here a few pics of some of the natural stones used.
The green one is Acapin Atagoyama used after the 1k Sigma Power- very muddy stone
Ohira renge suita
I also tried some others in the process to see how the stey respond to the steel.
I must say that Jnats work great with S30V, I have other blades with other steels in the queue (Elmax, M4, CTS-204P) that I am going to try as well
Holy smokes :eek: that's a serious set of stones you got there bro :D Have you tried any Infi on natural stones like that?.............. Thank's for posting:thumbup:
I am sorry I am kind of new to pocket knives what is Infi? Those Jnats are just a small part of my collection.
Great thread brother. These days I am getting lazier so I do pretty much all my sharpening on a 1x30 but there is no substitute for free hand, teaches you a lot.
Thank's bro, and yeah i know what you mean:D i am also getting lazier, i tend to use my beltsander more and more (3x55)
Lennox, in your opinion, can a strop be enough to get a factory INFI edge back to shaving sharp?
Also, what are your recommendation on strops? Should I just get the 50$ generic ones at my local shop, or should better money be invested into it?
Thanks
Kev
Thanks
Kev
If it's a factory convex from Busse a strop will in many cases (depending on how dull it has become) bring it back to shaving sharp. My NMFSHLE came shaving sharp but after a few days of chopping it would no longer shave or cut paper at all, 5 minutes on the strop and it was shaving sharp again, if i remember it correctly i stropped the NMFSHLE sharp again 4 times before i had to get the stones out.
The v edges that Busse put on many of Combat Grade knifes have a bit rougher finish and don't respond as well as the convex edges on the strop but after being sharpened on a fine stone or belt they can usually be taken back to shaving quite easily.
As for strops, I make my own and here is a good thread showing you how http://www.bladeforums.com/forums/showthread.php/640503-Make-a-leather-strop
If you want to buy a good strop you can try http://www.stropman.com or http://www.flexxxstrops.com/
