Lennox,
Thanks for starting this thread, there is a lot of great info here.
I use a 1-30 belt grinder and paper wheels to sharpen. I use the belt grinder to convex grind with coarse belts, and sharpen with finer belts. I use the paper wheel to remove the burr, it acts as a power strop from what I understand anyways. I like this setup because I can sharpen a knife, or lots of knives quickly. I try and gets lots of practice by sharpening all of the knives in the kitchen regularly, and I'm always offering to sharpen knives, axes, whatever for relatives and friends. I'm far from an expert, but getting better. The belt grinder works up a burr fast, which is great, but It can remove too much metal fast too, which can cause problems. I find that I often take too much metal away from the blade just in front of the riccasso, and blades that should have a straight edge end up with a slight recurve. I'm not sure what I'm doing wrong, but all my knives are users, so I'm more focused on getting a functional edge. I would prefer not to mess em up, but it happens sometimes.
I have used the sharpie trick before, but I would coat the edge, running the marker along the entire edge. I tried using the lines perpendicular to the edge, like in the pic in your first post, and it was a huge help. I found it much easier to see what I was doing.
I have messed around with cheap diamond stones, and sandpaper with a mousepad, but I find my current method to be the best with regards to being efficient. Sometimes I use a strop (I bought the bark river one with black and green compound) &/or a sharpening steel too.
Thanks again for posting all this great stuff.
Tim
Yea I must agree. Lennox you're help on this thread has been very valuable. I think I speak for everyone when I say thank you!
Lennox, first wanted to say thank you and to all who posted info thanks. This thread is full of great info
Well to update, I purchased a sharpmaker with the optional ultra fine triangle rods. I also just ordered strops from Flexxx strops, I went with the Jumbo and Tyrant. These will be my first strops and first attempt at stropping.
My first Busse I will attempt to sharpen will be a AMSCG, it's brand new. It's only cut some boxes and minor stuff, but it came kinda lacking the edge my other Busse's arrived with. I've tried the sharpmaker using the ultra fine rods, it seemed to help a little. Is this INFI that tuff that I need to do more strokes, I'm at about 40 per side. Should I work the blade reverse by dragging the blade up the rods, not down ? Just think I need a little guidance and practice, I've always had great results sharpening other knives.
Next on the list is to order some sharpening stones and possibly an Edge pro or EzeSharp.
Thanks again !
