- Jun 29, 2011
bring the two sided of your knife to the smoothest meeting point possible. i suggest mothers mag smeared on the inside of a bud light box.
I just bought a Gemini Light Brigade. Would I just sharpen it like I would a regular knife and then strop? I'm only worried because I only have one other Busse a NARC and I can't get it shaving sharp. The GLB is a shallow hollow. I think my Narc which is satin finished is Convex. Hoping the shallow hollow is easier. Should it be easier? Thanks.
The main reason people have trouble getting any knife sharp is that they are not matching the angle of the primary edge, and therefore are not sharpening the edge. Get a black Sharpie and color the edge bevel. then take a few passes with your sharpener. Now look very closely at the edge, and see where the black is missing ( a loupe or magnifier will help here). Are you sharpening right to the edge, or are you sharpening behind the edge? Adjust accordingly.
Your blade is shallow hollow but not your cutting edge, (Tglb on the right)
[/URL][/IMG]![]()
What you need to practice on is hitting the apex on your edge like Resin said in your thread.
Take a look at the steps i described a little further up using a sharpie, if you try these steps without any luck or want to try sharpening it in a different way, you can send me a PM and i will try my best to walk you trough it.
Len
+1
the grind geometry has nothing to do with achieving good cutting edge. In reality practice makes better, sharpening once in a month for example is not enough. This is a muscle memory based skill which deteriorates if not practiced on a reg basis.
Thanks for the help everyone. I will start practicing tonight on my NARC.
Got home and got to work on the NARC. I used the marker trick and it will now shave pretty good. I know it could still be sharper. My strop is ordered. Now I have to wait till it and my TGLB gets here. Thanks to everyone. I let you know how it goes with sharpening the new knife.
I got my strop and used it on my narc. I really dulled it. I went back and tried to resharpen using the marker method on a ceramic rod for about 3 hours. It still wont cut news paper, but it will cut hair when held at an extreme angle when shaving. I'm afraid to touch my TGLB now when I dull it.
I have DMT sharpeners, sharpmaker, EDGE PRO, crocksticks I can also use if that helps you. I can sharpen v grind knives easy. Since the TGLB is a slight convex would it be ok to sharpen it like a regular knife?
I reread the first post. I believe I sharpened the Apex only last night causing the blunt edge angle. I tried sharpening for 3 hours. Do you believe I can fix this on my own or will I have to send it back to Busse?
is evidence that you have been cutting down your apex to a blunt angle.it will cut hair when held at an extreme angle when shaving
Do you think I could use the edge pro to thin the area behind the apex? I have been trying to do it free hand and it does not seem to be working
