Matthew Gregory
Chief Executive in charge of Entertainment
- Jan 12, 2005
Given this is seven pages, I will post after admittedly only looking at page one.
I think this is reasonable and an admirable stance.
Some people might say the same about stamp collecting, or coin collecting, etc. And while I am neither, I don't think it is ridiculous that someone else is one, or both, or all three.
Too hard or soft for what? Rhetorical to make the point that actually some steels, with the right heat treatment, are just about perfect for a given use.
That's true.
You've seen from this thread that many folks are very happy to use things like 420HC and 1095. Those steels are used in copious amounts to this day. I do not consider that "antiquated", and by that measure, MagnaCut will never be.
Innovation produces breakthroughs that can improve the world. It's a process worth paying for in any industry.
You're not wrong if you don't care about steel innovation, or acquiring specialty steels. If you think the process of innovation is objectively bad, on the other hand....
The inventor has alleged certain properties regarding it. Those properties manifest consistently in use and testing. That's proof.
Great looking knife though, and agreed, I would not want to grind S110V at that thinness. MagnaCut, on the other hand, can be ground quite thin. I don't have any in the shop at the moment to put to the caliper, but I reground my Tenacious in S35VN to where is reads 0 at the heel, and .02 mm (ie .008") at the tip. I have never had edge damage, but I admit I don't baton carriage bolts with it either.
Exactly.
The second sentence is a direct byproduct of the first.
In this we are similar. I wear a carbon steel neck knife, even when its hot out and riding a bicycle hard. But evidently others in different climates and with different body chemistry will have different results than you or me. Nevertheless I am excited to claim a MagnaCut neck knife from my current run, so I have virtually rust-proof knife of my own again.
Quite so. Best balance yet achieved between the three cardinal blade properties as far as I can tell.
If you use and sharpen your knife, you will see the differences in steels. The problem is some people just collect these things like trading cards and say that everything is hype when they still have the factory edge and no elbow grease on the handles.
The biggest difference is being able to sharpen when you want to, not because you have to.
Heat treatment can also widely change the sharpenability even with the same steel.
Here's a fun little story.
I had a non-knife friend from work that only carried buck folding knives in 420HC.
It wasn't because he's a fan of the steel. He just doesn't care.
Well, I thought it'd be very curious to give him a a carbon tool steel knife. A CPM Rex 45 Spyderco military which measured at 67 HRC.
This is a steel that people would say would be way too brittle to be put into a bigger knife like a military.
He carried it everyday for over a year.
He has a piece of property and uses it for a wide range of tasks, not office use.
In his experience, there was a drastic difference in edge retention. He said his buck in 420HC would have gone dull in the first month of use.
The Rex 45 lasted an entire year with the same use He was quite impressed and as you can see he didn't freak out because his non-stainless knife got a stain on it. Let em patina boys
I did a bess test on the edge what I noticed is
that rather than the edge on a soft, low carbide steel being 1000g bess in the first month the edge stayed around 500g for a very long time rather than blunting completely smooth.
So, some of the problem I have with the knife community is that we have some folks pretending they're experts telling us different steels at high hardnesses are all hype when their knives look brand new, factory edge and they're just reading and regurgitating with other people say and not putting any time on the edge IMHO.
Both of you, stop making sense.
