FWIW, Iāve had neck issues and back issues (Iāve detailed the slipped disc issue in my lower back, and using deadlifts to rehab it), and have 2 traction devices:When I was younger, I went to the chiropractor for about a year. Not out of perceived necessity, but it seemed like a good idea and didn't know I had scoliosis until I saw the X-ray from my first consultation. One of the things he would do for me is provide neck traction on a fancy table that I could control with a handheld interface. I liked what traction did for me.
I almost bought this:
to hang from a tree branch neck to my pull up handles. Until I read the one star reviews. Then I realize why not ask someone I think might have a clue.
I wonder if traction may be a missing component to help me recover as fully as possible from my tweak back in the fall of 2023. Because my low back has never been the same since. B bluemax_1 (or anyone else) love to hear your thoughts, and if you know of an affordable neck traction solution.
Or other ideas to overcome the residual effects of a back tweak from an overzealous heavy (to me) one handed clean.
- a Teeter Hang-Ups inversion table
- a ComforTrac Deluxe Home Cervical Traction Device 2.0 (you can see what this device looks like on Amazon).
They both did provide relief when things felt off, but simply put, I havenāt used either one in years.
What I found worked for me, was strengthening the weak parts. That strategy may or may not work, depending on what issues you have.
I started rehabbing my back with bodyweight exercises, eg. Laying on the carpet face down, and then lifting my chin off the ground and holding. Then progressing to try getting my chin AND feet off the floor simultaneously.
Then when I tried starting deadlifts, I discovered that my back was in no shape to even get the bar with a single 45lb plate on each end, up off the ground.
So what I did was measure the bar height (since the starting height matters), and handle height of the dumbbells I have, and find something from the home improvement store to put the dumbbell handles at the same starting height, so I could start with light dumbbells for a simulated deadlift, and progressively add weight until I could do deadlifts with the barbell.
When I began trying to rehab my back, that disc would literally slip out of place multiple times every single day. Bend over to tie my shoelaces; it would slip out of place.
Sitting in a car for ~10 minutes = 50:50 chance of the disc slipping out of place by the time I reached my destination.
15 minute car ride = ~75% chance the disc would be out of place.
30+ minute car ride = 100% guaranteed Iād have to manipulate the disc back in when I got out of the car.
I was lucky that when the disc slipped out, it slipped straight back (so it made a visible bump in my lower back), away from the spinal cord, so there was no nerve impingement. I was also aware that there was a significant risk of turning that slipped disc into a herniated/ruptured disc if it got pinched by the two vertebrae when it was out of place, so I was extra careful when I felt it slip out.
I also was fortunate that I knew how to manipulate it back in place with 100% success. It usually took between 30-90 seconds of careful manipulation, and I could do it without pain, or risk of exacerbating the issue/injury.
As my back continued getting stronger; somewhere around deadlifting 225lbs x5, I realized that the disc was only slipping out maybe once or twice a week, instead of multiple times every day, and when it did slip out, it didnāt slip out as far.
Somewhere between 275lbsx5, and 295lbsx5, I realized it hadnāt slipped out in 2-3 months, so I continued. Currently at 210% bodyweight x5 reps. Not sure how far Iām going to push it, but Iām still seeing strength gains.
I did the same thing with the neck issues. I began using the towel to do neck exercises after my shower. Holding the towel with both hands on either side, pulling against my forehead, as I did 30 reps pulling my chin down towards my chest, then flipping the towel to the back of my head, and doing 30 reps pulling my head up and back (maintaining tension during the eccentric part of each rep, ysing my arms to pull down, as I tried to use my neck and back muscles to resist the pull , while slowly lowering my head forward, made the biggest difference to mitigating the ache. This is the same mechanism the Tyler Twist uses, for mitigating tennis elbow).
Since then, I also bought a NeckFlex harness for neck training. Been using that for a few years, now.
As mentioned, I havenāt felt the need to use the traction devices in years.
You mentioned lower back issues. Check Facebook marketplace etc. for listings for inversion tables. Iām sure there are more than a few people whoāve bought them, then wound up not using them.
The neck traction devices are less common. If youāre interested, drop me a PM. Iāll send you mine. All itās doing is gathering dust in a closet.
