@Docscoot
If you think there is a flaw or a defect with your inlays (or your knife in general), I recommended you first discuss it with Jordan. Just because there’s no more in stock doesn’t mean an inlay replacement or some other solution isn’t possible. Let Jordan help if you think it’s needed.
…anyhow…
Mail call happened and here’s the initial impressions of my knife. Note that I have no experience with real Ivory for direct comparison.
I can’t appreciate any material or milling defects with my inlays.
The inlays don’t feel plastic to me, at all. Much warmer. It’s not like any wood or G10 I’ve ever felt either. I would describe it as having the warmth of micarta (go figure) but with a satin quality that’s finer and more uniform than wood grain.
In person, the Elforyn doesn’t look like a plastic or resin based product. It looks white and uniform, but at the same time not quite pure white and not quite uniform. I guess that’s at least in part due to the grin structure.
How much these observations are due to the material and how much are due to finishing I can’t say.
The grain structure itself is mostly noticeable under close inspection; tangential light helps. My grain looks like radiating arcs, sort of like ripples in a pool. It doesn’t have any flower-petal arcs like the Mnandi posted earlier.
Other than the inlays, the blade is ground well and sharp enough; the stonewash is expected CRK qiality & etc. There’s no blade play or noticeable lock flex. Lockup is a little beyond 50% (ball on tang).
The action, however, is below expectation. The pivot is tight. It’s “this isn’t going to break in no matter what” tight. It’s something I will probably need to fix with judicious washer lapping at some future point. Overall it’s a keeper. But seriously, the folks at the bench in Boise should be taking a few extra minutes fitting the pivot & washers together.
TLDR.
