NickWheeler said:
First of all, posting images is not a big deal AT ALL.
The reviews contain lots of images.
But don't come in here and tell everybody how thorough your "findings" are
I don't. I in fact have said the exact opposite constantly. To repeat again, the purpose of the reviews is not to provide a definately statement about the performance of a knife (except to me of course), it is mainly to generate discussion about such issues, and allow users to ask informed questions to makers.
Chiro75 said:
I didn't make that assertion, for the record.
Yes you did, I quoted it in the above. I'll repeat it again :
"I assert that the above method could be used by an average person without a serious physical handicap to illustrate that there is a significant difference in soft penetration ability between the WB and the Military."
I picked the WB as it has the thickest tip I recall, so much so that I didn't figure anyone would argue otherwise. Again, I am NOT defining the limit of exclusion ranking here, just a starting point.
If you want to avoid dealing with the issue, then I'll ask an even more obvious question. Take a Military and break the tip off, now repeat the above. Note that if answer is yes then it proves the test is quantative.
It doesn't prove it is very precise however, but of course I never argued that. I do think it is a lot more precise of course, for example I would assert the Temperance would outperform the Manix, based on other work I have done.
I also don't know what your definition of "soft penetration" is.
Won't break the tip.
So, if these things you are measuring are so person-dependent, what is the point to doing them and making conclusions about them?
Because then you can learn about method as well. So for example if I compare two axes and Jimbo does and we get wildly different results we start up a conversation on method and see what that turns up.
Your findings may be different depending on your level of skill..."
Yeah it states this, they all do, or the recent ones anyway. There are like ~200, I don't think I added it to the really early ones, but they were really qualitative anyway. Some of the recent ones explore it in more detail, it often results from someone asking me a question or similar.
For example while I was doing the review of a long puukko I was discussing chopping with a guy with a vastly different method on really different woods so the chopping section in that review talks about how the relative performance of the Leuko can change vs other knives depending on method and wood type.
Rather than "knife A is superior than knife B because I conclusively proved it..."
Actually I would never say anything so vague, you have not defined how you are juding anything there and what qualities are being ranked.
What I would say is something like :
"The GB Wildlife hatchet is superior for thick soft wood cutting compared to a long bowie."
Then talk about what I actually meant (fluid, number of hits) how much superior, what methods were used (swing type, wrist action), what kinds of woods, what size, and so on.
I'd then discuss how these could be effect by various differences, what would make the performance go up or down depending on strength, speed, wood type, etc. .
I think you don't take that into consideration when you post your results
Of course I do, as I noted in the above, I avoid simple grading systems for exactly that reason, for years actually there were no conclusions, then Cobalt and others really pressed hard so now there is somewhat more, but as noted it still discusses endlessly that they are not so black and white.
Can you imagine what would happen if safety boards "concluded" things based on tests with this much subjectivity?
Yeah you would hope they would have different standard of variability. I work with highly toxic substances such as Hydrogen Cyanide and so on, I don't use the same criteria there.
-Cliff
