Ti frame lock. I didnt buy this as my first Ti frame lock though I coveted the heck out of the thing and thought it was so cool and modern that I simply had to have it . . . someday
because
I couldnt bring my self, intellectually, to buy a knife with Ti handles that I was arguing to be the ultimately strong handles for a work knife and at the same time buy one with a vulnerable ceramic blade that was more oriented toward gentlemans EDC
or
a master of knife handling :
Grasshopper, when you can cut your way out of this gauntlet of imprisonment and death with this Zircon bladed pocket knife . . . THEN . . . it will be time for you to leave the temple and go back into the world.
New nonEDC. I need to make that perfectly clear due to a conflict of interest in another thread.
First off remember the DLC blade coating that I was all excited about because it was supposed to reduce friction in the cut ? Then running the end of my thumb nail hard against the side I could feel very significant drag; more than what a regular uncoated blade has.
Eureka ! The polished Zircon ? ? ? ? (says Zr02 on blade) near the spine of this blade is like running my thumb nail hard against greeezzzed ice ! Oh YAH ! (there is drag in the hollow ground area but only on non rigid stuff like when cutting lettuce etc.)
The
edge is polished from the maker as well and is decently sharp. The last ceramic knife I bought, a white bladed neck knife was a joke in the sharpness department though billed as Ten Times Sharper than something or other.
I realize this knife may have its vulnerable, questionable . . . even flawed areas . . .
but
It REALY does it for me in MANY respects. Blade thickness 0.1 inch (2.5mm) (I wont have to grind it thinner). Interesting the weak blade has a thinner blade than the super steel blades of similar ilk. There are many things in this world I dont understand. Cripe it even has a low ride Ti pocket clip.
I finally couldnt help my self . . . the temptation is strong and the flesh is weak.
Gives me a another project : get a paper wheel(s) for my grinder and learn to sharpen ceramic right. I cant wait !
PS: the online review said the should loose the lanyard hole so it could be shorter and lighter and that the handle was a bit large for the blade. I totally disagree; see how it fits in my palm; I dont need the lanyard hole but I WANT the handle length. Perfection there and part of the reason I bought this knife; the ratio of blade length 3-1/4 inch to full size handle length. I wouldnt change this.
