- Jul 1, 2014
Blee... That sure is a beautiful knife.
As far as I know, there is no reason to stabilize mammoth ivory. The ivory has been on the earth at least 10,000 years, and is a hard material. I think the material is worked down so that the cracks are on the surface only. Tough stuff.
Two major knife handle material suppliers that I checked both offer stabilized mammoth ivory. One also adds this disclaimer: "Most mammoth has small cracks and voids. These sets will likely have some and some will be more than others. We have pictured the front and back of each set of scales to help you decide. Fixing mammoth scale cracks and voids is normal part of knife making but I understand some may not want to do that. If you want perfect, slab them on scales, these are probably not for you. If you want to make them solid and fill the gaps or cracks, its fairly trivial. Use thin super glue to fix the cracks. Simply drip it into the cracks and let it wick into scale and cure. For the bigger gaps on the back, use gel or thick super glue and glob it a layer at a time until the void is filled. On the surface of the scale, glob it in and lightly sand it before it dries. The dust will blend with the super glue and make the repair neat and clean and it will look just fine."
I've never worked with mammoth ivory, so I don't know if it's always necessary to stabilize it, but at least some of it is stabilized, and apparently it's normal to have to repair some cracks whether it's stabilized or not.
