- Apr 15, 2002
ignoramus said:I respect your opinion, but it sounds like your just saying it's better without any rationale behind it. Would you mind elaborating on why you believe what I said is wrong and the smaller blade is better?
A smaller blade is
A. easier to conceal
B. less likely to have legal repercussions
C. usually is part of a knife that offers a smaller package, one that you are more apt to have on your person EVERY DAY, instead of the big 4.5 inch blade fighting folder, that is heavy, uncomfortable to carry, difficult to conceal, does not fit with every outfit you wear, and is apt to be left home, and remain there when you need it most.
D. NKP friendly. a smaller blade is less likely to scare non knife people, and I am a proponent of USING a SD knife for the daily mundane tasks, so drawing and opening the knife become routine and ingrained.
E. In a self defense situation, you won't be duelling an opponent. Your knife should not be for show. Most likely it will be an ambush, in a confined area. A smaller knife is less likely to injure you, the user, in a close quarters situation, than a larger one, as well as being easier to access.
D. and in a self defense situation, you are looking to use a knife to facilitate an escape, not finish off your assailant. A small blade cuts a hand, wrist, or forearm just as easily as a longer one, and if that arm is around your throat, a native is going to be safer for you the user than a military.
and if you are worried about your SD blade being dulled by day to day chores, most of the higher end steels will get you through every day mundane cutting needs without losing too much cutting abilities, and nightly touchups on the sharpmaker are a simple and efficient way to keep the edge up to par.
Peter
