You can find something on usamadeblade.com
Kershaw makes a good knife. Kershawguy.com is always my first stop when looking for a Kershaw knife.
You can find something on usamadeblade.com.
The Buck Vantage line are for the most part well made and in the USA. The cheapest line is the "Select", followed by the "Avid" and "Pro". You can get the "Select Large" which has a 3 1/4" blade for a hair under $30.
The Vantage knives are nice. You might consider saving up for a month to add 25 dollars to your budget and getting the Vantage pro with s30v steel with an excellent heat treatment (Paul Bos). Very good ergonomics. Pivot may require some adjustment, but a great value.The Buck Vantage line are for the most part well made and in the USA. The cheapest line is the "Select", followed by the "Avid" and "Pro". You can get the "Select Large" which has a 3 1/4" blade for a hair under $30.
Kershaw Tanto Zing 35 bucks from kershawguy!
esee candiru
The Buck (and Leatherman) 420HC is a really good steel thanks to the heat treatment.
It's better than any current 8Cr models, and on par with Cold Steel's AUS8, and on a knife that you can pick up for under $30 that's pretty good.
