Ah, good. I see the "classic" version comes standard with it yes.Thanks! And yeah, the "Classic" kit comes with the fine tuning adapter.
Gosh I hope TSProf doesn't also go on sale now too and I end up with both. FML. hahaha
Use one clamp on the flat tang area of your knife (to stop rotation/wobble), and the other clamp on the spine closer towards the tip of your knife, maybe an inch or so from the tip (to stop flexing). Using most of these systems this way gives the best results.
Interesting, thanks for the reply.
So when I do that, the clamp on the tang has all the pressure on the front edge of the clamp, since the clamp has some angle built into it. So you end up with one clamp having the hotspot on the end of the clamp, the other having the hotspot on the back edge of the knife, and they do indeed balance out to preventing rocking. But man, eww, this doesn't seem icky to you? It looks like so much clamp is on the knife but in reality it's only touching along two fine lines.
This works better than an adjustable clamp because the adjustable clamp flexes more?
Yep, the K03 is a great piece of kit. Pricey, but worth it!I just sharpened 2 knives with the TSPROF, and this thing is outstanding.
I love being able to use the angle cube between each stone to ensure the angle hasn't changed. And adjust the angle easily with the dial. And the spring-loaded stops on the arm so that I don't accidentally go too far in either direction while sharpening. And the nice wide clamps that hold my 10" kitchen knife with no problem.
I'm not sure I need to open the Hapstone R2 box. It probably gives me most of the above, but the TSPROF is so solidly built I don't see why I wouldn't keep it.
I still think the non-adjustable clamps might give me trouble for certain small knives. And I don't like that I can't place them dead center when needed, so I may end up buying the center, angle adjustable clamp. But I'm fine doing so if needed.
I have both the spring clamps and the milled and use them both as needed. I used plasti dip on the ends of the milled clamps for blade protection and grip. I have no issues with blade movement. I also used the plasti dip on the spring clamps, more so for rust protection and blade protection. You don't need both types of clamps, but it helps.
I went to the K03 and KADET after years using Wicked Edge and for me, it's been a game changer. You're really gonna fall down the rabbit hole, as I have, with the K03.
Great point. I'll keep them naked, and ensure both the knife and clamps are clean before each usage.Be careful with a rubber coating or pad on your clamps. If it does get contaminated with, let's say diamond powder, and you clamped the knife with the swarf or powder on the clamps, the grit can embed itself deep into the rubber and you may not be able to clean it out. You could end up with a clamp that will then always make haze / tiny scratch marks on your knife, and you'll have to completely remove the coating to get them clean. (Depending on the rubber / silicone type.
Which additional clamps do you have? If I don't keep the hapstone and use 777 Edge's Gearconnect clamp adapter idea, I'm thinking of getting this TSPROF clamp for when I want a smaller knife more centered.
Каталог
shop.tsprof.com
I was looking at that one but it says "We do not recommend to use it for knives with a spine thicker than 2.5 mm." Some of my kives (such as the Small Sebenza) have a blade that is 3mm thick. The Umnumzaan is 3.5mm thick. I figured it's a bad idea to overdo it?This version (fillet) of the TSPROF clamp will serve you better with small and knives. And if you don't keep the Hapstone, you won't need an adapter for this clamp.[/URL]
..The Umnumzaan is 3.5mm thick. I figured it's a bad idea to overdo it
