Masteroffajitas
BANNED
- Oct 7, 2008
That's how I open my native sometimes, it got so smooth with the rem oil I put in it, I can get out by throwing it really fast then stoping it.
The very fact that the knife has a detent (regardless of if it functions properly or not) can be used as an argument against it being a gravity knife.
The fact that a knife can be legally misconstrued as a gravity knife DOES NOT MAKE IT A GRAVITY KNIFE. It makes the laws where you live restrictive, invasive, and abusive of your rights... but it doesn't change the actual, factual, technical definition of a gravity knife.
Two plus two does not equal four even after Big Brother passes a law saying that it does.
I agree to Phil regarding false definitions and his following conclusions.
But considering the definition, given by artmichalek:
If an officer takes the blade and uses centrifugal force to open the knife he is actually releasing the handle from the blade. That is right the oposite from releasing the blade from the handle.
I don´t believe, that would make a difference in the real situation, but that is the problem, Phil is talking about.
It makes no difference, how false the officer is acting, it makes no diference, how false a gravity knife is defined: You are in trouble without causing it.
What does it mean, if you can´t be sure, that you are acting legally or not?
If you can't handle that, you can go right on believing that the letter of the law redefines reality.
Sorry, Phil. The term "Gravity Knife", for the purposes of the Courts and the Law is the legal term - the term specifically defined in the Criminal Code - i.e. "Gravity Knife". Big Brother, in the form of a democratically elected Legislature, defined the term and the Constitutionally constitued Court interpreted the term in the context of the legislation.The fact that a knife can be legally misconstrued as a gravity knife DOES NOT MAKE IT A GRAVITY KNIFE. It makes the laws where you live restrictive, invasive, and abusive of your rights... but it doesn't change the actual, factual, technical definition of a gravity knife.
Well, in this case the letter of the law does define reality. The OP asked about the legality of the knife, not Phil's conceptual interpretation of the physical mechanisms behind gravity. If he runs afoul of the law, he goes to real prison. Not conceptual prison.
And again, this law was passed by a democratically elected legislature. It is the will of the citizens of New York. As far as I know, it has not been brought before the Supreme Court on Constitutional grounds. I'm not saying that I agree with the law, only that people are inherently incapable of oppressing themselves.
Sharp Phil meant 2 plus 2.What math class did you take?
2+2=4.
It really does.
I'm confused by your analogy. Can you explain?
2+2=4.
It really does.
You Canadians are starting to get out of hand!I thought the same thing, but it likely means that 2+2 IS 4 no matter what the law says. It equals 4 because it equals 4, not because someone passed a law that made it equal 4. At least that's my take on it.
Still toying with the table we may learn a few interesting things. As everyone knows, 2 + 2 = 4. This is true in all base systems. That is, except bases 2, 3, and 4. In base 4, we have 2 + 2 = 10. In base 3, 2 + 2 = 11. However, recollect that (4)10 = (10)4 = (11)3, and everything falls into its right place again. Numbers equal in one base are equal in any other base. Conversion between bases does not violate arithmetic identities. In base 2, 2 + 2 = 4 appears as 10 + 10 = 100 - looking differently but having exactly the same meaning.
What is a "gravity knife"? That is an arbitrary term that has no "objective" meaning.
