I understand wanting something fine just to own it, and have no quarrel with that.
But when it comes down to using the knife I use mine to cut a cord, open a package, or maybe tighten a loose screw. The SAK takes care of those thinks in an excellent manner.
Except for the screwdriver the Boker Magnum I am carrying does the same things.
So for those who own expensive knives, what do you do with it that a much less expensive knife, such as a SAK, will not do?
If you like to admire the workmanship, and know it has the best steel that is fine. But how do those things translate to everyday use? Do you really tighten screws and cut boxes with it?
Thanks,
Jerry
More expensive knives USUALLY have better steel, which means longer edge retention (sharper for longer) AND superior geometry (lower edge angles and primary grind can be better) which creates a knife that will cut more easily, for long periods of time. Other than that, handle ergonomics MAY be involved, high end materials and finer fit and finish give more pleasure to many users (not necessarily you).
Fixed that for you.
I see what you did there
By 'more expensive' I was meaning ~$300 as opposed to a Boker Magnum ~sub $60. I don't know of any $300 knives that aren't antiques that have a lower end steel than a SAK.
I guess I was a bit ambiguous, but it made sense to me![]()
But what will those expensive knives do that a SAK will not do except give you the joy of ownership? The SAK will cut boxes and tighten screws. while I doubt any of you use your knives for that purpose.
Thanks,
Jerry
Do you drive a kia?
Would you say that about a Hyundai Genesis?![]()
riginally Posted by jerm03
Thanks,
Jerry
The bolded part sounds more trolly than inquiring.
I use ALL my knves to cut things, be it boxes, rope, sandwiches, tape, string, wood, plastic, zip ties, wire, whatever.
I use a screwdriver with interchangable tips for tightening screws.
My S90V Para2 loves boxes. It's got some of that urban camo glue on both sides of the blade.
Unless you're investing, you might as well use them.![]()
This is not an attack at you but you should take a step back and read the context better, he is in no way trolling or acting with hostility. IMO this has turned out to be a very interesting thread on personal 'knife philosophy.' Interestingly enough the only posts so far that seem to be slightly inflammatory are the ones scattered through the topic, making assumptions the OP is somehow trolling, poor, or cheap.
Nobody's opinion or 'knife philosophy' is right or wrong, good or bad, just different. I find it interesting to hear others beliefs and use their opinions to rethink my own.I assume the OP intended the same.
