Utility wharncliffe folder?
I would probably say the Kershaw Leek either in the sandvik 14c28n steel which is a good steel or the composite blade with a D2 edge both USA made, I am pretty sure you could class the leek as a wharncliffe anyway, plus its a great EDC to have in rotation.
BAD IDEA. Anything you get is going to get scratched and the edge ruined. We use sandpaper to SHARPEN knives... so no steel is going to stand a chance against this material. I have done it before, but with a beater knife or utility (disposable) knife. Not with a $200 blade!
True. For sandpaper, I use disposable razors in a Stanley knife.
This is what I been carrying...
[video=youtube;A2D2x-j3zDU]https://www.youtube.com/watch?v=A2D2x-j3zDU[/video]
Not one-handed, but this traditional folder by Northwoods has a nice big handle, and is a workhorse of a utility knife:
This one is called the Forest Jack. The Fremont Jack and Michigan Jack (if you can find them) are also nice options.
Here's my Fremont, which is my most carried of the three:
how about the Camillus Heat, Wildfire or Sizzle (all the same knife with different blade lengths. it uses the hawk lock which is my favorite lock, one handed open and close is very easy. i havnt tried that specific knife but i do love my kershaw ram which uses the same lock. its designed by grant and gavin hawk.
aus8 steel which isnt top of the line but is good enough, ive always been happy with aus8
also check out the zero tolerance 0770, it comes with an elmax blade but is also available as distributor exclusives in cpm-M4 and M390
i had the m390 version and its an awesome knife, easy one handed open and close. ZT in my opinion make the best production knives on the market and they have great customer service. 90% of the time i have a ZT in my
pocket
there is also an aluminium version that is cheaper. its been discontiniued but is still available from some of the main knife retailers for $120 or less, i think it will be hard to find a knife that well made with a steel as good as elmax for less then that.
The Kershaw Barge--when it eventually comes out--is another one to consider, and it gives you an integrated prybar.
Cut the backing not the grit side, and really just lightly score it then tear it. If you can do it in the air all the better. I usually use a GEC 47 Viper so I would notice if the tip was getting worn down by it.
I'd look for one of the Razel folders if you want a straight edged work knife with a stout blade. Not quite what you asked for but somewhat similar in use.
You guys do take these threads seriously, thanks! :)
Cutting down Opinel is probably not the right way to go - the resulting blade would still be too flimsy.
Also the Kershaw Leek, while a really nice EDC (I did test one once shortly), has way too thin blade for this purpose.
Viper Dan2 does look very nice - this must be the first flipper I have even seen that is a slip-joint :)
Dustar cutter Jack - nice concept, but I am not sure what level of sturdiness should I expect from it.
19-3ben - it does take actually very little pressure with the Delica to have the tip wander away (like cutting along steel ruler)
Boker Anso could be an option in a pinch, even if the blade is on the large side.
Hackenslash - thanks for the feedback on the Kizer Pinkerton Rogue - that really could be it!
Camillus Heat, Wildfire or Sizzle - seem to have a bit awkward shaped handle - more directed to pushing than pull-cutting.
ZT0770 in M4 would be a killer knife - I am off to check it out! ... it is a bit on the pricey side, but looks super cool and seems to have the right design too.
Kershaw Barge - has about the right blade side, what should I expect from the steel?
Northwoods folder - I LOVE those knives. I actually have one (the Willamette whittler) - and it has a lovely whatncliffe blade, but the handle has all the wrong shape for heavier use (too small and gets thinned toward the butt). The blade would be up to the task. Larger jack would be great, but I would not be able to open it with gloves I fear. I had very hard time not to buy the GEC 47 Viper when it came out, now I regret that.
Kershaw Needs Work is a great candidate for this job IMHO>. :thumbup: I had a red one but sold it... :( It was a great cutter though. :thumbup:
Oh I didn't know traditionals were on the table for discussion?
Gec 72! This one is a lockback.
Sent from my SM-N900V using Tapatalk
Camillus Heat, Wildfire or Sizzle - seem to have a bit awkward shaped handle - more directed to pushing than pull-cutting. (ive held one and the handle is surprisingly comfortable and with the deep choil and aggressive jimping in palm area you should have a problem with either push or pull. its less than $50 so it might be worth it to try it out. if it doesnt work well you can always sell it for probably only a $10 loss
yea the m390 and m4 are expensive due to their limited edition status. elmax is a very good steel, i dont think you would be disappointed. the aluminium elmax version is about 1/2 the price of the carbon fiber M4 version. since your knife will be a user i think the aluminum elmax version would be the best choice of the 0770 models.
best of luck trying to narrow down the field of amazing knives
I barely manage to keep up the speed here :) Thanks for all the tips and advices.
The kershaw needs work seems a bit on the large side, but yes, it could work.
As much as I like the small griptilian blade shape, the usable handle is actually smaller than on small sebenza which I sold because of the handle size.
Cold Steel Tuff lite - I actually wanted to get that knife in the past and then didn's - it does have a very utilitarian shape. I may give it a try.
The traditional folders are only mentioned because I have a soft spot for them Usually - once these have large enough handle, the blade is already a bit long. Buy yes - it would be an option
The 'simple' ZT0770 with Elmax and alu scales is actually available also here in DE - that would be an advantage or (most) other candidates as I could just sent it back if I do not like it.
Hi,
since I have built my mini knife making workshop I have much more use for a true utility blade. I have got the Delica HAP40 and while it is a great knife, it does not suit the task well as the blade is to thin and flexes a lot. The use is cutting all possible materials including sanding paper, cardboard, wood, etc.
I am on the search for a utility folding knife with the following properties:
- wharncliffe-ish blade cca 2.5" - 3"
- preferably flat grind (no hollow grind)
- steel that holds decent edge, ease of sharpening not relevant
- full size handle (I often wear working gloves when I use the knife)
- one hand opening (and ideally also closing)
- up to about $200 (less is OK)
I have searched, but did not manage to find an obvious candidate so I though I would ask.
Kizer just released a s35vn wharncliffe with ti framelock, 100$. check it out
I love my Kizer Pinkerton Rogue. The handle is long enough for a full 4 finger grip, so long as your hands aren't larger than medium sized.
Thanks. I have not personally handled one, so I couldn't answer the OP's question, but that sounds about right, based upon the videos. :thumbup:
