The point that it does prove. . ."use the tool for it's intended use/purpose."
Besides, while engaged in cutting something ~ when would you ever exert enough force on the spine to cause the lock to fail ?
Posted by JT:
"Well, it's a fine argument for gentleman's knives -- if all you're doing is trimming your nails and opening envelopes, it's very easy to control the forces on your knife. But if you're doing even moderate-duty cutting, it's not so easy. If you've been paying attention, you'll have read of real world liner lock failures like the following:
1. User is cutting plant stems, gets knife stuck in stem, and it fails as he pulls it out.
2. User is cutting cardboard and the cardboard binds up the blade. When he does what anyone would do -- torque it out a bit -- liner lock releases and cuts him.
3. User is cutting and the knife binds. He pulls it out a bit too hard, it springs out and the spine hits a work surface.
Thundered from the mountaintops by Sal Glesser:
Michael, I'll stack Spyderco linerlocks againse ANY custom made folder for reliability and strength.
Originally posted by GigOne
Mishap records show that approximately 88% of all mishaps are due to the unsafe acts of people while an additional 10% are due to unsafe conditions not identified or corrected by people. In other words. . .98% of all mishaps are due to unsafe acts and conditions caused by human beings and are therefore preventable.
1. User is cutting plant stems, gets knife stuck in stem, and it fails as he pulls it out. If a stem gets caught in a liner lock ~ it can't be too large and no way in hell could it cause a liner lock to fail. Unless your "user" torques the stem in a fashion that causes the lock to unseat.
User is cutting cardboard and the cardboard binds up the blade. When he does what anyone would do -- torque it out a bit -- liner lock releases and cuts him. Here is a prime example of the "user" causing the lock to unseat.
User is cutting and the knife binds. He pulls it out a bit too hard, it springs out and the spine hits a work surface. I take that your example of "springing out" refers to the knife being released from it's binding state? If "user" properly gripped the knife, it binds up and "user" pulls it out a bit too hard and it hit a work surface ~ "user" would hit the work surface with his/her hand or fingers.
If you've been paying attention, you'll have read of real world liner lock failures like the following. . .
Not sure what you're trying to imply here Joe. I've been paying attention and I've yet to read nor see substantial proof that liner locks fail.
Pay attention here Joe. . .I'm not talking "your moderate-duty cutting" here ! Have you ever shoved a liner lock knife into someone wearing body armor Joe? Well I have ~ and it was "a real world liner lock" and the lock did not fail. The difference though. . .when I pulled it out. . .a rose stem wasn't hung up in the lock nor did I torque it to the left of right nor did it bind as I withdrew it. Amazing isn't it Joe ?
Like I stated earlier. . .(and above wasn't a isolated incident) I've been using liner locks for years. . .20+ years Joe. . .and in very severe and extreme conditions (and you can't get more severe and extreme than in my job). I've never had a liner lock fail when used for its intended purpose and when used properly !
Originally posted by Starfish
Mr. Glesser,
That is a very strong statement indeed. Are you stacking Spyderco linerlocks up against linerlocks on any other custom made folder, or against any other lock, period?
It would be interesting to hear your point of view on the liner lock versus other (Axis, rolling, etc.) locks!
Respectfully,
Matthew
