BluntCut MetalWorks
- Apr 28, 2012
This simple test aim for wear resistance, NOT looking for: edge-retention, cutting efficiency, so on.. 12 knives/steels cut palm frond & 0.5" sisal rope on an end-grain cutting board. Edges will be prep for optimal workable durability in push & partial slice cutting style.
Setup:
Initial sharpness = slice newsprint. Make 10 cuts -> clean apex at sustainable angle. Make 10 cuts -> clean apex again at sustainable angle. Now we've an edge optimal for cutting frond/rope. This way we eliminate bias/early failure.
Test:
Palm Frond. Non-tearing slice newsprint: test edge after every 15 cuts. Note - most working edge would fail this test, so failing isn't really dull.
0.5" Sisal Rope. Non-tearing newsprint paper: test edge after every 50 cuts.
Cut sand. Non-tearing newsprint paper: test edge after (round 1: every 10 cuts) (round 2: every 1 cut)
Here are 12 knives. 3 from commercial production (BM, Spyderco & Mora). I made the other 9.
Palm fronds
A sample cutting test video - http://youtu.be/kkgaYpNtAEg
[video=youtube_share;kkgaYpNtAEg]http://youtu.be/kkgaYpNtAEg[/video]
**Shamelessly** I ignore minor variables at play for this test: edge geometry + blade profile + other variables + forces + vectors + reproducibility +
PALM FROND & ROPE CUTTING == A FAILED SETUP!!!!!!!!!!!!! date:20131115 :grumpy:
K390;52100;15C28N;1084 knives made 1700 rope cuts and with a little or no sign of failing. So I decided just keep testing only 1084 knife, well now it's at 2500 and still pass newsprint slicing with slight noise. At this rate, 1084 probably make 4000+ cuts.
Then it occurred to me that this entire test (palm frond & rope) is about blade against the cutting board. As I've noticed along the way that every miscut of frond = small chop to the cutting board. When doing rope, there hardly any miscut, so the blade mostly landed not hard + some wood slicing motion. That's why 1084 still going strong at 2500 cuts.
Palm frond Results - #s of cut:
Final:
15N20 - 480
Mora carbon - 570
14C28N - 1425
1084 - 1425
zdp189 - 1965
s35vn - 2280
cpm-154 - 2325
cpm-m4 - 2475
k110/d2 - 2550
s30v - 2850
52100 - 5250
k390 - 6100
0.5" sisal rope Results - #s of cut:
On going (then abandoned)
1084 - 2500
K390 - 1700
14C28N - 1700
52100 - 1700
Cutting sand results - #s of cut:
Box cutter - 10 (which mean after 10 cuts this knife no longer cleanly slice newsprint with grain at 30-45* angle)
Mora carbon - 10 | 4
Opinel #9 carbone - * | 5
15N20 - 10
1084 - 20 | 10
Zdp-189 - 20
S30V - 20
K110/D2 - 20
S35VN - 20 | 17
14C28N - 30
CPM-154 - 30
52100 - 40
CPM-M4 - 50
K390 - 60
to be continue...
Setup:
Test:
Palm fronds
Final:
15N20 - 480
Mora carbon - 570
14C28N - 1425
1084 - 1425
zdp189 - 1965
s35vn - 2280
cpm-154 - 2325
cpm-m4 - 2475
k110/d2 - 2550
s30v - 2850
52100 - 5250
k390 - 6100
1084 - 2500
K390 - 1700
14C28N - 1700
52100 - 1700
15N20 - 10
1084 - 20 | 10
Zdp-189 - 20
S30V - 20
K110/D2 - 20
S35VN - 20 | 17
14C28N - 30
CPM-154 - 30
52100 - 40
CPM-M4 - 50
K390 - 60
to be continue...
