- Mar 7, 2001
1050 wow
Since I can't imagine unobtanium, I'd choose #1.
I've most of DMT diasharp 8x3 line (XX to EE) and diamond compound+suspension (15um to 0.1um) and some CBN as well. For this test, I use diafold E to tune the adaptive micro-bevel, so the edge probably has toothiness of equiv to 500-600 SiC/waterstone. I didn't bother tune high-carbon knives with waterstone, if they slice newsprint smoothly, good to go. Plus I keep the same finishing grit baseline for all knives by using dmt E.
*update* 1084 is still going after 1050 cuts - some micro chips but still slice newsprint at 30* off grain.
That's very interesting! How are you executing these cuts, is there a bit of draw or is it more of a pressure cut? I'd expect 1084 to perform well, but not that well, am wondering if it has to do with how the cuts are being made. My carbon steel machetes (1075) can hold up to tremendous abuse as long as they are finely polished and I don't draw cut much with them. Once I start to use friction/draw cutting they dull very quickly.
Martin
Chris "Anagarika";12820240 said:1050 wow
Since wood has silicates in it (microcrystalline quartz), I wonder if your cutting board should be made of Corian (Methylmethacrylate). While the Acrylic board is harder over all, it is still softer than cutlery steel. The wood board is softer over all, but has inclusions (quartz) that are harder than the blades being tested.
I enjoy any testing so thanks for doing this.
I would be curious to see when one applies higher load (weight) on the knife when cutting if there is any wear advantage with the different steels. Reason for my curiosity is because of this paper:
ftp://ftp.asm-intl.org/pub/MARC_Records/V07/asmhba0001587.pdf
A steel such as S7 and A2 seems to be better wear resistant then even CPM-M4 or D2 under "high stress abrasion". Wonder how that might translate into a cutting edge?
Know this is not really contributing much to your testing, but I am tired and rambling so forgive me.:foot:
Chris "Anagarika";12826243 said:Not Kershaw steel. Same steel Kershaw uses, HT and finished by bluntcut
Lol
Sorry, can't help it but I also have tendency to take same assumption. No offense, but unless it 's HT the same, even same steel will have different performance.
I know Kershaw does their HT to 58-60, usually on the harder side. I said it is Kershaw steel because that is where most people know the steel from.
HRC does not mean much, the entire heat treat process, skill in sharpening and final geometry greatly affects performance.
14C28N can achieve 58-60HRC in three different heat treating approaches.
I am not surprised to see 14C28N perform similar to a carbon steel since it was introduced as a more corrosion resistant alternative to 13C26 or AEB-L and those where introduced as steels that have similar properties to carbon steels with higher corrosion resistant properties.
I can say one thing. You know your edges !!
Can't wait to see the rope results.
Chris "Anagarika";12829949 said:Bluntcut,
Just watched the video. The word 'tough' isn't enough to describe the frond![]()
Wow, the rope is far worse than the fronds. Now I am interested to see how the other steels perform on the rope.
