- Apr 24, 2011
I cant believe that nobody else is on board with a Uber BK-5 a 14-16 inch BK-5 would be the sickest machete in history
A Brute that works the way we wish it would, or the way it looks like it should - maybe a little thinner in the handle, possibly the handle angled a little more like the Machax, narrower blade towards the handle......Hell, I don't have a clue what would make that thing work better - it just looks like it could be a great knife.
Thanks, Dubz. I guess I'm wondering why there's so much area in the ricasso, and why the thumb depression as well - they seem to serve no purpose; with the edge starting so far out from the handle it doesn't look as if you'd be able to do any fine work. Come to think of it, while I love the large Becker scales, it seems like all of the full size knives could use a scale redesign that lets you choke up a little easier; something like the little depression on the TOPS B.O.B. Imma hafta experiment with that when I get around to finishing some of those wood scales I've got lying about.
1/4" thick, 10" long blade, chisel tip, full flat grind. Think of an Ontario SP8 on a becker handle with some tweeks that I think it could use. Notice how I didn't mention a saw back. The saw on the SP8 sucks so just leave it off.
Maybe even more than that I'd want a BK14 with a chisel tip symmetrically ground blade about 3-3.5" long.
I would make a BK-5 with a 14 inch blade.
Yes, it does suck. But it does not have to suck. I modified mine quite nicely with my dremel tool & a cut-off wheel. First, i sharpened up all the edges of the saw, then, i cut grooves across the saw teeth tops at an angle. It now removes wood like nobody's business. Does not clog up either. I did NOT sharpen the first 4 closest to the handle as i use them for/as jimping. The saw back will now cut a notch a 1/4" deep in wood in about 30 seconds or less. :thumbup:Easy peasy. Took like 5 minutes or less total.
Anyone else here think of the Cold Steel warlock when they read this?
BK14 with izula II handles....(wished for this for a while)
Never heard of it and a google search got nothing.
Typo...Warcraft tanto.
