pat9198
- Jul 21, 2021
5 weeks on the 119, just got it in!I also placed a separate order for a 119 elk magnacut but nothing on that yet.
That’s coolOn a roll this week in acquiring Bucks. This 196 Alpha Hunter Alaskan Guide Series is now on its way to me:
I had a Tops knife with a difficult snap.Here’s the 4 dot I’ve been waiting on. It’s in nice shape, couldn’t have been used much. The snap on the sheath is ridiculously hard to snap shut and release. Anyone experienced this before? Any tips to improve it?
Thanks for the tip.I had a Tops knife with a difficult snap.
I took a pair of needle nosed leathermans and gently crimped around the outside edge of the larger snap.
And then oiled it a bit. It works better.
I'd suggest try snapping each of those snaps onto something else to confirm which part of the snap is the problem first. Mine was the larger outside one. It didn't want to snap onto anything.
Jon, good find. Those are hard to date.I have not had a chance to date it or anything
Thank youJon, good find. Those are hard to date.
From 1973 to 1981 they were 440C steel, then from 1981 to 1992 425M but no marking to indicate what steel.
The knife remains looking the same(black phenolic), with the same tang stamp until 1986 when Buck added date codes.
The sheath , if original, helps because it looks to be the earlier one that used the single Buck on the snap. From L. Odin's book this snap was used 1973 -1981.
So, I think, yours is dated some time between 1973-1981.
Someone with more knowledge may be along and correct any mis-information I have put here.
Nice find! I think you’re going to love the Mesa! It’s almost identical to the 104 but with a slightly larger finger guard and a slightly different handle shape. The weak point is the sheath. It also came with a better sheath that looks more like a Ground Combat Knife sheath. But the Mesa fits a 104 sheath perfectly and you can buy one from Buck’s website for $30. Less if you’re a BCCI member.On its way to me: A 632 Mesa. Not found in any of the Buck Dealer catalogs, but the model number (0623GYSWM-B) indicates it was a Walmart Exclusive model. From my research, it seems to be a slight variation on the 622 Endeavor, but with a plain edged blade without serrations and a different color (Gray) Handle (The 622 handle was Black)
None of the Walmart models are "rare" but this "Before the Compadre" woodscraft knife will make a good field, working item,
Nice snagOn its way to me: A 632 Mesa. Not found in any of the Buck Dealer catalogs, but the model number (0623GYSWM-B) indicates it was a Walmart Exclusive model. From my research, it seems to be a slight variation on the 622 Endeavor, but with a plain edged blade without serrations and a different color (Gray) Handle (The 622 handle was Black)
