- Sep 17, 2007
How to accept knife damage is your fault
Alot of times it is.
Not always, and as I was not the person using it I cannot say in the case in question.
But alot of times it is.
Wrong. :thumbdn::thumbdn:
Study the history to discover the Bravo-1 is a hunting knife modified to meet the needs of a small group of Force Recon Marines.
They required a GP/Utility knife to handle cutting chores, not a "survival" knife.
The knife has become Bark River's biggest seller because America's knife user's like a knife that cuts; sharpened pry-bars are all to common in the knife world, when in reality other tools are better suited for such tasks.
Somehow some fools think the Bravo-1 is designed to cut concrete blocks and car hoods; get a clue, it's meant to slice the things that need a sharp edge for cutting.
One thing I see here is that BRKT is missing a huge opportunity. They should offer classes on proper knife use to prevent this type of thing. Topics could include how not to whittle a chopstick with a blade >= 3/16" thick, and how to chop branches 3/4" diameter or less. How to accept knife damage is your fault and how to be content when we grind out damage instead of replacing a faulty knife are acceptable alternative topics.
A huge opportunity for Big Mike!
What I do know though is that in the 4 inch range of blade, I never chop.
4 inch bladed knives are great for cutting...although I prefer folders in that blade length.
Bigger knives, like in the 8 inch and up range are great for chopping. I'd be pissed off if my knife in the chopping type of design chipped.
Also - have you seen the video linked in this thread where a chunk falls out of the edge of a Bark River because the owner tries to use it to SLICE a chopstick?
I tend to put more stock in the experiences of people I know the habits of.
No, I have not seen that video, but at times I wonder what use the knife had that we're NOT being told of beforehand.
Is it the first use of the knife? Or was it used to wail on seasoned oak for 18 hours beforehand?
I'm sorry, but this makes no sense to me. First of all, the idea that misusing a knife can delayed damage in cutting is one there is no evidence for. De-tempering doesn't happen this way. Secondly, it would take an amazing conincidence for the knife to be at exactly the right point so that the blade would fail the very next time it was used to cut at the spot tested. It would just be impossible for all practical purposes. If 18 hours of oak bashing was required to weaken the knife, then you'd have to not only give those 18 hours BUT NOT ONE SECOND LONGER. The odds against this are millions to one.
OK, here we go...I really want to know why the hell you guys think you need to chop and baton wood all the time, I make knives, and they will stand up to this, but why? I have spent as much time outdoors as anyone, I have had years where I spent 200+ days living in a tent in the woods. I have lived in a tepee that I made myself in Alaska. All this said, I have never "needed" to baton or chop wood with a 4" knife, NEVER. I have always either cut with a machete, or hatchet. If I dont have either of those, I simply build a fire/shelter with sticks/branches that I can break by hand, or with leverage. Now, I know this is off topic, and that knife should not have failed like that, none I make would have, if so it would have been money back, or full replacement. Really though, whats up with this type of mindset that you feel like you need to do this? Is it to test the knife? is it because you saw it on some web site, or some fake reality series? Im not trying to troll here, I just want to know.....
No one mentioned detempering...don't know where you got that from.![]()
As for use causing breakage later on, here's one for you...
I had (well, still have) a paring knife. It is a decently made, name brand knife. It was never used to smash logs, pry anything, or anything abusive. It was used to cut vegetables and meat, and always with a proper cutting board.
One day, I went to cut (not chop) a carrot...and the blade did not chip; it split in half.
That's right, I now held in my hand a knife with a blade half as long.
I reground it into a far shorter sheepsfoot paring knife.
So don't tell me that a knife cannot be pre-fatigued by use, or that failures are a "millions to one" occurrence, because I have experienced it.
I've also had screwdrivers that failed from turning screws (after years of use).
I've seen a pry bar break at an annoying time.
If all these were "millions to one" occurrences, I'd be far older than 35.![]()
It was literally brand new, and he showed the knife taking the damage on film. It's irrefutable. He takes a clean, new portion of the edge and push cuts one of those super soft disposable chop stocks, and it completely warps the edge. Pitiful.
You can clearly see in the video that the knife is ground wafer thin. Like literally wafer thin at the edge. Is it really hard to believe that an edge will fail under normal cutting when it is ground that thin?
ETA: Oops, didn't see the post above me.
