Thanks everyone, I appreciate the feedback.
Cold Steel was my first knife, Voyager I think. But I dont care for lockbacks.
I can carry an auto, Launch is on my radar.
That’s too bad. CS is really hard to beat here. +1 to American Lawman for people who has similar criteria but are ok with lockback/Triad lock.Thanks everyone, I appreciate the feedback.
Spyderco sage ... pretty dope in FFG ...for around ur budget...
Can you please point me to $100 sages........
Do your homework, I've bought 2 of them in the past for around $115-$120 shipped. =D
they only go for around $150 brand new...
I figured if the OP could flex another $15-$20... he could get something really great for cheap!
What is the difference between the CS Triad and standard lockback?
IIRC, the Triad lock is essentially a lock back with a stop pin added. The stop pin helps counter vertical play and makes it stronger.
If I'm wrong, someone will correct me.
Doc’s right. I’ll add that while the stop pin is the main difference that transfer the load to the handle, the other thing that makes triad lock truly strong is the way the lock contact the blade tang. Unlike typical backlock, the contact of triad lock is angled in a way that forms a hook. IMO this is where the tru strength comes from. The only way to achieve this is to give the lockbar ability to travel forward and back, instead of just rotating along the lockbar pivot. This is why the hole of the lockbar pivot is oval instead of round.You are totally correct .
The Tri-ad lock is also self adjusting as it wears in over time . It will retain a rock solid lockup for many years with no fussing .
IMO describing Triad lock as a lockback with stop pin is over simplification because of the above. The change in the lockbar travel and the contact may be less visible, but has significant impact.
