dantzk8
Basic Member
- Nov 1, 2005
I’d like to see some in process pics of one of those.
Here is.
I use a 2x2x2 inches (5x5x5 cm). Each face of the cube is divided in 1 cm side squares. The greyed squares are the extremities of the rings.
Remove the wood around the rings.
Until you get this :
Take care to the symetry to don't end up with twisted rings.
Now you have to separate the rings. It's the tricky part. I advise to work on both the 3 rings progressively to don't break one of them.
If it works you will get this:
Now you have to refine the rings shape.
Two things to take in count.
More you progress smaller the chips. Initiate carefully each cut to check you don't work against the grain with the risk of a split.
In a previous post i've mentionned i soak the wood. I've to correct one thing. Before working on fine details it's better to dry the wood slowly in a cold place like a fridge. You will get neater cuts.
Now sharpen your 62 and enjoy !
Dan.
