- Oct 25, 2010
Depends on the knife. On my large fixed blades they need to push cut paper relatively clean. On my smaller fixed blades and 3.5" and under folders they need to shave.
Right now I just have one old combo stone set, triangle with 3 stones from coarse to fine, about 2"x7". the coarse is totally out of flat though. I have a couple old razor hones, but they're for touch ups really, a full sharpening or setting bevel would take forever. I don't want to buy traditional stones if there is a better way.
Thanks all.
Red
I'd go for either Paper Wheels or a Work Sharp Knife & Tool Sharpener(I strongly recommend aftermarket Micro-Mesh belts with that) for power tools. When sharpening with either, the belt/wheel should be moving away from the edge. If you turn the edge into the belt or wheel, you either cut the belt/wheel or have the blade fly off somewhere.Ok, so what really is the best sharpener to get? Do I get belts and a guide for my grinder, and does it need to be going the opposite direction? (i.e. if the knife's spine is against the rest should the belt be turning away from the edge or towards it?) Then get something to hold the blades at the right angle till I get it down freehand? And what does a person need to sharpen recurves?
Thanks all.
Red
I need to get the sharpmaker ultra fine rods.
Thanks Dale. Been doin some homework on the subject as far as angles go, so I'm getting a better understanding. The knife I've been practicing on is shaving sharp, but I'd love to get it to push cut by sharpening it freehand if possible, although I have been checking out the lansky set-ups
Ok I have had about three hours worth of time touching my knives up freehand on the Sharpmaker stones. I am happy when I have the knife sharp enough to push cut receipt paper, or shave arm hair without effort. But I know some can get knives insanely sharp, so is my standard of sharpness pretty low on the spectrum?
To me it is hair whittling. Like here:
http://www.youtube.com/watch?v=Pr1Fnf5yxsI
It take about 5-10 minutes to do this. See tutorials:
http://www.youtube.com/user/nozh2002#p/u/77/5TscN9h-1xQ
Thanks, Vassili.
I watched video. You use Dia-sharp x-coarse, coarse, x-fine then strop? No other plates required?![]()
X-Coarse is extra step to put initial edge if needed, at first or if edge is severely damaged, otherwise coarse then fine then strop.
You may see from the video it works just fine for over 3 years (see date stamp on video) - so I made conclusion that no other
steps are really necessary. Of course sharpening is in big part meditation and from that point more sharpening in between - better
but I like it myself am not in guru business.
Thanks, Vassili.
Thanks - that will save me some money!![]()
If you are free handing all you need is 3 stones, Coarse, Med and Fine and then a strop if you want to take it higher and or remove the bur.
And even then you would only use the Fine and the strop for maintaining.
You could get into the EX Fine and beyond that if you wanted to really refine the edges, but that gets into money, can be serious money depending on the stones you by like 15,000 grit and up Japanese Water Stones.
For most stuff a Norton Fine Stone would be enough.
I'm getting DMT plates to replace the dia-folds I've been using with great sucess. I think I could even get the 6" - 2 sided sontinuous plates. I'm use to using about 4"s so another two would be awesome. I can't see getting the 8" models since I don't sharpen tons of knives and none are tha large - up to 4" blade folders.
I should be able to get 4 grits in the dual 6" plates.![]()
