Regardless of what everybody else says about a knife, if it isn't for you, you don't "need" one.
Think twice buy once.
Avoid the impulse buys and save for "the one" that you've been obsessing over. Smaller purchases add up quickly.
Don't accept most of the technical "knowledge" from most people on this forum without having a good reason to listen. The more you know through first hand experience the more ludicrous and asinine a lot of it sounds.
Other than that, usually you will find more effective use out of thinner blades than you can comprehend right now. Doesn't matter the steel. Unless you absolutely need a big honking prybar go for as thin as you can get within reason. With a little bit of experience you'll learn what that is. You almost most definitely DON'T need any kind of folding knife designated as "hard use" unless you simply want that type of knife for no genuine reason and just want it for the sake of wanting it.
And arm hair shaving should be the bare (no pun intended) minimum for sharpness. Like you were just feeling lazy when you sharpened that day. When you get to that point you can really start assessing steels. If you keep them less than that who cares about steels. Buy a cold Steel in AUS8 or a Spyderco tenacious or Ontario rat or Kershaw blur and call it good. When you can really sharpen and maintain your stuff then go into the higher end stuff where you can make informed decisions that YOU know will work for you.
And you'll find yourself coming to this forum for a lot of knife knowledge. Don't let the trolls and rabid fanboys dissuade you from coming here. There are a lot of good people willing to help minus those guys.
Another pro-tip: don't accept ANY technical "knowledge" from bodog.
Point made.
Either:
1) Buy a knife because you think its the sexiest thing ever; or
2) Buy a knife because you have thought about what you want to do with it, the knife is designed to do that, and you understand how the knife is designed to do that.
But don't confuse the two, or kid yourself one is the other. That's a waste of time and money.
