- May 23, 2021
Just overall, Knifesteelnerds scored D2 with a toughness factor of 3.5/10. Someone on another forum also was kind enough to provide the following, since you seem to want to avoid answering the question (perhaps you knew where I was going with it?)Do you really think it is as simple as that? No consideration for blade thickness/width/length???
A toothpick made of D2 will break a lot sooner than a 1" diameter bar of D2.
Please try to put some intelligence behind your questions.
D2 toughness is 5 ft*lbs, A2 is ~15 ft*lbs, L6 and 52100 - 25 ft*lbs, 5160 - 45 ft*lbs, 8670 - 50 ft*lbs
I'm not really looking for a pocket knife to butter my bagel from the coffee shop on the fly whenever I'm out. I'm sure D2 would be enough to suffice for such a task. If you're happy with it, great. All the power to you. You're probably older than the patent belonging to D2 as well. Doesn't mean I should stick to ancient relics that were the best choice available almost a century ago.
