- Jul 20, 2021
No. It's in the OTHER book...In the book I read the answer was 42......
Your response didn't come across as condescending in any way, you're fine.well technically I am sitting in a rocker on the back porch smoking a cigar, so you're half right there.
no I was being honest , helpful and serious...I was trying to be clear and precise without being wordy like I am here in this post.......
Do you guys just sit in your rockers all day shaking your fists at those 'young whippersnappers' trying to create discourse on a public forum? I seriously don't get it..
This is a very courteous response, I thank you kindly for it. Some would do well to take note of the civility contained in such a response and apply it to how they interact with others on this forum in the future.No one knows what that steel that is because NASA keeps it under lock and key. They ain’t telling anyone either.
As far as what’s available on the market today based on your description, it doesn’t exist. Repeating what’s already been said, there’s always a trade off.
‘if you want to know what the trade off is, that will have to be another thread.
If I ignored you, would that prevent you from seeing my "absurd posts?" Or you can likewise ignore me, if it elevates your blood pressure to such a degree it makes you uncomfortable..You'
You have been a member here for over 6 months. You should know that there is no such thing as the "ultimate" steel.
Stop with your absurd posts please.
You just had to do that, didn't you.....‘if you want to know what the trade off is, that will have to be another thread.
Well, sweetheart, what are you waiting for?Over 20 years on this forum, and I have only ignored ONE person. There is a high probability you will be number two.
And I am quite cozy and comfortable, and my blood pressure is fine per my physical last month.
Search/read more, post less.
There is no actual answer to your OP question and the explanation of why is very complex .There is no single "best" steel.
It depends on your intended application.
And even the "best" steel is totally dependent on the proper heat treatment.
great point there, Sir. can't forget geometry...very crucial to performance.The quality and capabilities of a knife blade are not the result of the steel alone. There are other very crucial factors, like the heat treat, the grind, and how it's sharpened.
You could have a blade made out of the most expensive knife steel on earth, and although it might be very high-quality steel, if the blade doesn't have a good heat-treat (too low or too high) and cannot hold an edge, or chips with normal cutting, then what good is the steel.
When it comes to steels, there is always some amount of compromise. For example, some steels (properly heat-treated) might take a sharper edge, and hold it longer cutting tough material, but it may be highly susceptible to rust and corrosion.
But these are things you learn over time. There are decades of combined knife and steel knowledge here at Bladeforums. Knowledge on topics like blade steels, edge geometry, heat-treat, etc, all things that factor into the performance of a knife blade. Such knowledge doesn't come quickly, it takes a fair amount of reading and commitment to learning.
If you're serious about learning, I hope you are able to make the most of this forum, and that knowledge, just as many others have.
I noticed we touched on the same topics. I'm sure we were typing at the same time, I'm just a bit slower on the keyboardgreat point there, Sir. can't forget geometry...very crucial to performance.
