- Jun 17, 2001
Ron, two weeks, two weeks, two weeks.....
fitzo said:Ah, now I understand! There's a lot of nut there to squish. Or is that nutbag??
I'll get that S30V chopped off the bar today. Been stuck inside cuz of the ozone for three days......
measure of PSI
My design incorporates die storage into the H frame. Pics to follow shortly.Bruce Bump said:It should have a locking system so the dies dont move yet easy to remove and replace dies with forging gloves on
It should have an adjustable pressure relief valve so even a 35 ton press will pop off at low pressure for fine forging of tips and tangs. This valve should be easily adustable with a knob instead of an allen wrench.
The hydraulic oil tank could be part of the square tubing or an enclosed side of the I beam.
All hoses need to be shielded to keep hot billets from burning holes in them and allowing 2500 psi of oil to spew out. I wonder if it would be flaming oil?
The ram needs to be long enough to allow the billet to be squished from end to end.
It needs a two stage pump that will deliver at 11-13 gpm and an 1800 rpm motor. (my motor is a 3 hp and spins at 3600 rpm and is loud)
A foot control would be nice so both hands could be used to hold those heavy billets.
The height should be high enough to see with bifocal glasses (for us old farts)
A huge selection of dies sets on a tree that rotates for easy pickins.
Ron Claiborne said:Dream press
Thats a tuff one .
One that mash out 1000 dollar bills oops 5lbs steel in the minds of great masters mashers can produce that .
One that makes every thing perfect and fast hummmm that would be boring ,
One that has great control so that I can determine its effects on the steel .yes
One that I can gang mash Buicks together hence car crushers 100 tons and up
one that fits my shop and needs ---- am I mashing Buicks for projectile in the desert or building a billet for a one of a kind folder .
One that has ram speed that I if I blink I can see the $1000.00 billet change into 20 dollor disk that looks like road kill
one that when I start it I can lock it in and go grind a few blade or call Kelly for more steel
do so wire inlay start a new press with a bit faster ram speed ( O ) thats what we are talking about .
I do know that its hard to time a speed when you are only a 1/4 from your work each time unless you have a controller that will lift the ram all the way back up but surly in this day and time one would know not to use that for sure.
One that is at a good viewing hight so that it can be watched, a little over 40" high .
Hand or foot controls I like hand controls I have more control in my hands than my feet and I dont like doing a balancing act while mashing steel
One that is quite so the people down the street want call the swat team in because they think im killing people during the night .
One that I can convince my wife that its the best can crusher money can get honey you can stack a cas of cans 2" tall just think of the room your saving at the recycling place
Easy changing dies again speed is not the biggin here they slid they fit they hold heat
Dies heavy for holding heat and strong .
One that changes as do my needs ----- if I could know what that might be, that would be great
Free
While im dreaming can I get it in red
Bowie Damascus free
I have a die designed to do the bevels. Pics will come tomorrow. Im sure everyone will tell me if i am full of crap or not. Im looking forward to the feedback.ysforge said:Dream forging press:
Whatever one can be done next week(I was gonna say whatever one could be done for free, but that qualifier on the price kinda killed that)
Seriously, I've seen some pretty neat presses, one of the local guys uses a press that's horizontal, he's got dies set up so that he even uses the thing to put the bevels on the blades as he forges them out!
Tony
Ron Claiborne said:ps -- i can send egg to prove this you will see no cracks in eggs
