- Sep 13, 2004
I have a ram designed that i think would eliminate alot of the play you are talking about. It has 2" cold rolled x 15" long for the guides with a 4" long tube collar. There are Zerks on the collars. The top plate is 1" x 7" wide by 15.25" long. The pic shows the ram with a set of squaring dies. There is a set of drawing dies in the storage rack in the lower right of the pic. All the component bolt into place and there are slots for adjustment to insure that everything lines up. It can all be taken apart and every part on the guide system can be replaced. There is no welding on the guides except for the 2" round bar to the bottom plate witch is made of 3/8" mild steel. The top ram plate has .375" gussets, 1" plate for the cylinder attachment and is welded solid. I dont have the bolts shown in the pic but they are all 3/8" and there are no holes drilled into the vertical tubes. there are threaded buttons welded to the vertical tubes for the top bracket to bolt into. There are holes drilled into the bottom plate for the base of the guides to bolt to.Mark Williams said:Nice looking drawing.
Assuming you are going to use the side rails as the die guides, I would make the distance between the upright rails much smaller for less lateral play.
So tell me. What wont work?
