Artfully Martial said:For that matter, is there anyone that actually flicks their sebenza?
No, because we are all grown ups that dont need to impress their friends.
Artfully Martial said:It seems to me that problems related to flicking the knife are the result of bad craftsmanship
SpyderJon said:Now, I'm not trying to start anything, which is forum-speak for me pulling on the flame suit, but just what is this magical quality that the Sebenza has that these people will be missing out on? Before you ask, I've had three of them. I didn't get the magic. It was well made. Nothing more, nothing less. I have a Buck/Mayo 172 that I've carried for the last 2 years. The lockbar hasn't moved at all, and its just as good now as it was when I first got it. I think the Sebenza would be better represented as what it is- a very well made knife in the upper end of the production world- rather than given some kind of mystical quality that only owners can understand. Its a knife. No more, and no less. I mean, I'm up front with my sometimes less-than-stellar opinion of Striders (though I EDC one and personally like mine), so what is the harm in doing the same with CRK? That is, of course, keeping personalities out of it and just going by the knives.
So you "baby" your Sebenza!When the blade pivot wears out and you have play in the blade is why. Check your pivot lock-up, if you are habitually flicking, the blade will have some play in it (if not now, it will eventually). My Endura certainly did after flicking it for a few years (that is why it sits in a box at home), so did an AFCK (a much more expensive loss).
I could "flick" the blade on my Sebenza open, but why would I want to put undue stress on the pivot bearing, the stop pin and the lockbar for no good reason?
I own several assisted-openers and a few autos as well (switchblades), and I can tell you with 100% certainty that they are no stronger than an non-assisted-opening or non-auto folder in regards to the pivot and stop-pin.The lockback bar may be fine, but the pivot is not designed for high speed-high torque "flicking". If you want to open a knife fast, why not buy something designed for it like a gravity knife, assisted opener or switchblade?
If you disassemble an auto, an assisted-opener, and your average "tactical" one-hander you will discover that there are no real differences in pivot or stop-pin strength.Your Kershaw bump isn't likely to have a problem as it was designed for the SpeedSafe system. (Switchblades and gravity knives obviously also have no problem with high-speed and high-torque opening) Most other knives are not designed for this.
But basically you "baby" your Sebenza and you don't put any undue stress on it.My Sebenza has been opened in excess of 10,000 times with the only evident wear in finish. The lock-up and blade movement are still practically zero.
I'm not sure that a ceramic ball is better.From JoHnYKwSt:
This is why CRK uses a ceramic ball rather than steel. Reinforces the idea that lock quality also needs to be taken into consideration and not just lock type.
Well, you are certainly entitled to your opinion, and if you are content with a knife-maker forbidding you to do something that most other knife makers have no problem with, then more power to you.Because there is no real need to flick it other than to satisfy someones IMHO childish needs. If the maker of the knife says dont flick it, then dont flick it, dont have a tantrum fit and squweem and squween until you are sick.
Lemon328i said:In that vein, isn't it mystical?![]()
allenC said:I'm not sure that a ceramic ball is better.
We often use ceramic rods to sharpen blades, so I wonder what effect the ceramic detent will have on the blade over time?
With most liner-locks and frame-locks that I've seen, one can easily see a wear line from the ball-detent contacting the blade.
Will a ceramic ball-detent eventually wear a "track" in the blade?
Temper said:Do whatever you want, flicking to me is a waste of time, if I have taken the time to put the knife in my hand its just as easy to open it with my thumb as it is to flick it.
I think that most of us knife nuts baby our knives to some degree, and there's nothing wrong with that.Django606 said:Since when is "babying" a knife a bad thing? I don't know where the hell you come from, but I like taking care of my knives, as they are tools that I know will serve me well when treated with due respect. What are you suggesting we do with our Sebenzas?
