What blows my mind is people who are content to carry a dull knife every single day until someone points out that it is dull and offers to sharpen it. Why do they even have it? Also, when someone asks you for a recommendation and you point out a $20-$30 knife in their price range, and they still end up getting a $5 gas station knife.
Spydercos are fishing knives and what is a sabenza? This thread...
Sabenza?
Badass pic, stabman:thumbup:![]()
AND make supermodels fall in love with you.
Thanks.
I was doing a bit of urban exploration, and found this great spot under a bridge where the train tracks end (they used to extend to a ferry crossing to Detroit waaaaay back in the day, before the tunnel under the river).
Looks to be a prime spot where bored teenagers pretend they're in gangs, and there's evidence of hobo activity there too. :thumbup:
The "knife of the day" just happened to fit really well into the setting.
Moras - primary grind way too thick for good cutting, takes too long to resharpen because of all that steel that has to be removed. I have several, they make good garden knives, that's about it for me.
Opinel - great geometry, cheap steel. If they would make an Opinel in a really good, high hardness steel, I probably would sell the rest of my knife collection, no joke.
Sebenza - great ergonomics and tolerances, just can't hold an edge. For this much money, it should be able to hold an edge longer than VG10 or AUS 8A. Mine couldn't, got rid of it.
While I love super steels, I'd be quite happy to spend the rest of my days with a Vic Huntsman or Farmer.
Yes, I know what you are saying. The scandi edge is very thick, and requires a great deal of metal to be removed to sharpen if they are a zero edge. If they have a micro bevel, then they would be much better served having a full flat grind with a MUCH smaller primary angle (and therefore relief), and would work much better. For wood working, I haven't found them that useful. At all. They are good for a cheap knife, but that's about it, from what I've seen.You know that Moras are meant for wood work, right? They are the perfect design for that. I have no idea what you mean about removing steel, as most Mora knives come with either a zero edge or a very small microbevel. Maybe you just use them for the wrong thing. They are not EDC knives.
I sharpen my moras quick and easy... put the bevel flat on your stone or sandpaper and do a few passes on each side... razor sharp in like 1 minute or less
Exactly. These things are purpose designed much like many more expensive offerings from the same region. Quick sharpening and excellent on wood. I guess different people have different sharpening techniques and uses. No harm, no foul.
Different strokes for different folks.. but I have a feeling if he new how to use it and sharpen it sodak would be amazed at how they carve and cut wood I sure was... and my first sharpen I was like WOW shaving sharp with no effort.
I have to admit though, that I use my flat ground mini Classic and Companion just as much, although I choose the 510 for messing around with wood because of the Scandi grind. FFG cuts wood pretty well, it just doesn't split the fibers quite as well as Scandi. However the FFG Moras can't be beat as neck knives/EDCs.
I've used moras for a long time - over 20 years. There are many grinds and knives that are much better, both for wood as well as other things. Using and sharpening these are not the problem, they are fine for a cheap knife. But they don't come close to better designs.Different strokes for different folks.. but I have a feeling if he new how to use it and sharpen it sodak would be amazed at how they carve and cut wood I sure was... and my first sharpen I was like WOW shaving sharp with no effort.
