- Jan 17, 2008
I was using Combat Abrasives for a while there but switched to VSM for reasons of economy. They cut well and the price is right.
I think I get a lot longer life out of 36 as well. I either have to be doing large blades or hardened blades to keep from getting deep gouges that can be deeper than expected.It used to be the same for me, 50 grit to start.
Then I couldn't get 50 one time so I went with 36 cause I needed to resupply.
I noticed afterward that it seemed as though I was getting more life from the 36.
That made things easier when I went to 60 to start cleaning the rough stuff up.
36 is rough and will almost throw chips when really hogging.
When I was roughing those four choppers I filled my bucket with 1/4" to 3/8" long slivers.
Big Chris are these what you use? Thy have a few colors.
About 5200-5500 SFM, roughly 98% of what my grinder will do.
As for pressure, I'm roughly 380 pounds and I'm leaning into it.
If I don't run at full or near full speed, in the motor's optimal torque range, I stall the grinder out, it's 2 hp.
I'm probably not applying the pressure a robot is but I'm not babying it either.
Yeah I’m grinding hardened AEBL so I’m torn on what belts to order. I dont normaly work with stainless so most of my stuff was carbon and a 50 grit blaze.
I don't claim to be the best grinder but I did go through probably 4k worth of belts at pops prices last year. That seems like a fair bit at least for something that's a hobby. I focused on different techniques and using different belts. You definitely should have scotchbrite belts. The difference between scotchbrite and cork that I have noticed is that the SB is more satin and the cork is shiny. You can dress a fine worn scotchbrite and get more shine. Working at Hewes Marine we went through so much Scotchbrite on the aluminum boats I tried to make it do to much at first. I find that with both it is important to have a very nice scratch pattern from your gator or AO belts. They refine what's there but don't give a new pattern. In fact trying to hard and taking off all the pattern seems to look bad. I would be very interested in trying a brown scotchbrite, they are very aggressive.I have never had a problem with the blaze and thy have allways been good to me. Besides the occasional wabble. I’m so use to 50 grit blaze I’m half tempted to just stick with that grit. I jump stright from 50 to the A300 gator and then the A160 or A100 and top it off with either the A45 or A65. Then hand sand if it’s needed. I’m kinda thinking about trying thoes magic cork belts everyone is talking about or a scotch bright.
I just ordered 8 Blaze belts form Pop's. I have not used them for several years because of the "black gunk" issue, so it will be interesting now that the have apparently solved that problem.
