- Sep 10, 2010
VSM all the way. I honestly don't notice much of a difference between VSM and the nice belts like cubitrons.
I have some cubitron 947 (medium pressure) and man they are leagues above VSM, combat abrasive, or even 3m 707.
So if the 947 are that good i cant imagine what a 984 would be like
Everything seems to be creeping up in price. I just looked at my last bulk belt order (February) and both ceramics and AO belts have gone up 10 and 20% respectively. What was a $500 order is now a $575 order. And February 2018 was 10% more than April of 2017.
So you use the 984F in 50 grit on hardened stainless? My other thing is coolness. I would rather sacrifice belt life a tad for a belt that cuts cooler.
Yeah, we had a steady increase in many things from big gas prices a few years ago, but then pretty static prices during the low economy for a while, then a cycle of increased competition to recapture market share, now rising import costs, and a more stable economy seem to be causing prices to creep up quick. Typical cycle I guess? =\
i like the cork because they last and last. i usually wreck one accidentally before it wears out. i have a 400 i have been using for 2 years.
The J flex at 220 grit might be nice for a few things.
I m glad that you get improvement with modification .....I don t think that 60lb spring will have any impact on motor , especially not on bearing .Speed , yes .... but not that much to worry about that .Ive got 10 of the blaze 50s on the way to compare to the more expensive yellow cubitrons. Ill also give my vsm veramics another go now that i have direct drive set up.
Does anyone have any thing to share on how these belts/grinders compare to higher tensioning? I notice vast improvement in belt life and speed with my 60lb spring as opposed to the 20lb I used to have but is this going to have a negative impact on the motor and other bearings over the long run?
