In general, I'd like to see MAP disappear, cheaper costs for high end steel, more customization options available on production knives, & ample stock and supply of popular brands in order to prevent gouging.
There's already plenty of those and have been for years...
Ive always wanted a folder where the pocket clip completely disappears, with a glass breaker that is like a retractable ballpoint pen to open it to clip on to your pocket. I would also love it if Frank and Todd Fischer made mid-techs, so i will probably pound sand on both of these.
How could zt improve the durability and simplicity of frame/liner locks?
By designing or optioning a stronger, safer, easier-to-use lock. Liner and frame locks are not terribly strong, require exacting geometry to get right and place your finger in the path of the blade. The clearest example of a lock that's just objectively better than either design is the compression lock. Stronger, safer, no more moving parts, just all-out better design.
They experimented before and it really didnt prove very fruitful. The offset and mini mojo/mojito had the stud lock and I dont think they were incredibly popular in their time. Either way if ANY lock fails while you are using it then more than likely your fingers are going to be in the way of the blade. Sure when closing a frame lock or liner lock knife you finger is in the way of the blade as you close it but you should be mindful of what you are doing. The risks under use are the same for all locks if they fail.
-A spyderco classic 50s style Italian stilletto. Polished g10 handle, polished steel bolsters.
That would be great.
I would like a CS American Lawman with upgraded steel in larger size, if with 5 inch blade I would buy it instantly.
