What's happening in the David Mary Custom shop?
I like to take my hair down all the way every couple months at most. When I was a teen I had the long hair, and it was all wrong. You know, I just now wondered if my haircut all through school may have been..... polarizing to people in how they viewed me. What is a normal haircut anyway? 🤷‍♂️
I'll do a childhood haircut reveal if three more people ask for Slyvan choppers in 8670. :) Or anything big in 8670 really. If you're in, could you head over to the thread and help us decide between 3/16" and 1/4"?
No. Five people. It's embarrassing enough that I want to significantly lessen the odds of having to do this. So if six more people ask for a Sylvan chopper or similar before I set up for my next 8670 run, I will do a childhood haircut reveal. But nothing lower than the eyebrows.
Thank you Martin, it is Frogblanks laminated wood.
Started with reblades this morning, now that I have a basic process laid out, and got most of the work done on the two knives loaned to me by BFs members. Then gave the second half of the the day to this short notice commission for another kind BFs member who just messaged me today.
Thank you again sir! I can’t wait to have it in hand.
Oh my I just realized it's been that many days since I posted in this thread!
So let's see, the New River Knife Works hawkbills have been released from Customs to Canada Post, but they weren't at the post office today, so I am hoping tomorrow. The ferric chloride for etching Damascus arrived last week, but the hydrochloric is still in transit. My eight sheets of Boltaron and thousand eyelets arrived.
The only fresh belts I have are for New River Knife Works, hence not starting anything new up lately, other than the ones that have gone to the Exchange. Once I finish the hawkbills, I'll make my largest grinding belt order yet, which in turn should allow me to finish knives faster and better, since I would not be bottlenecked as I am now. With five sixpacks of each of my grits in stock at once and my ongoing experience with this grinder, I should be able to put in more steady shop time with more and greater results to show for it.
Some of you are already familiar with "the pile" as I call it, of no-longer-fresh grinding belts. The ceramic belts I use cut extremely fast for the first several ounces of stock removal, and the progress on blades is quick. But they slow down to a working level of sharpness before too long. They'll still remove stock, but at a steadily decreasing rate, and as they smooth over, friction increases, and thus heat. The unconventional way I grind allows me to comfortably keep my fingers splayed out over the length of the blade so that I can instantly feel and react appropriately to any degree of heat increase. By the end of the working sharp phase, when belts become a blade burning liability, I either toss them out, or relegate them to jobs like profile hogging, or and handle shaping, where they cannot do any damage. It's at this point they collectively become known as "the pile". Here was the pile at the start of my time in the shop this afternoon/evening:
You can see handle material and steel embedded in them. These ones are at varying degrees of sharpness, but none of them is suitable any more for coarse grinding the geometry, at least not efficiently. The worn scotchbrite belts still work for finishing, but unlike with ceramics, actually take an order of magnitude longer to get a similar result, and require a dip on every pass so as not to cause a mild surface discoloration on the blade bevels. Needless to say, I don't want to be grinding and finishing 30 hawkbill profiles on worn belts when I can get nice results much faster on fresh belts.
So now that the @New River Knife Works job is the shop priority, the entire pile got moved out of the rotation and replaced with the belts I ordered for it, a handful of 120 grit belts I found stashed at the bottom of a box. These seem to the longest lasting grit for me, which is funny to me because I have learned I can skip the "recommended" step of 60 or 80 grit between my 36 and 120. Which in theory means my 120 grits work the hardest, since after that is 220, and then coarse, medium, fine scotchbrite for a slightly convex belt satin finish. I am sure you can visually see the difference between the fresh belts and the pile even in jusy the photos.
And of course I still have the pile because it comes in handy for all kinds of little jobs, too numerous to try and list. But handles, sheaths, makeshift tools, etc, can all benefit from the pile, which saves the fresh belts for blades. I still have the pile, I just shoved it off to the cluttered side of the garage for now that has some of my stuff but mostly Chris' family's stuff.
The aluminum platen that came with the grinder is not perfectly flat, which can make grinding precision much more challenging. So I removed the paint on the platen, roughed up the surface with a diamond plate, and began using pyrocermaic glass platens a couple years ago.
My platen changes have sometimes been difficult for a variety of reasons, but I am pleased to say that my platen change process went off without a hitch today. You can see the old platen has some chips out of it, most notably along the left edge (bottom in pic). I used to think that the chips were actually problematic to getting a good finish, but they don't give me a problem any more. I can't say exactly what in my grinding technique has changed, but perhaps it's just my general grinding awareness that continues to improve.
I took it off the grinder, turned it upside down, and poured a few drops of acetone into each of the two holes I drilled in the aluminum platen. I wish I had thought to do this from the start, but alas, I did not. I have had platens glue on there so securely that I literally had to grind the little shattered bits off with a diamond plate. That was not fun. But this time (and the last) the plate came off with a quick pry underneath with my indispensable shop tool, the humble putty knife. Which I then used to quickly scrape away most of the glue so I could start again and install this new platen:
Step one is finished on all thirty blanks, which is to first create the most important aspect of the knife: the APEX. If any of these look off or asymmetrical bear in mind that the pic is quite blown up so imperfections that you might not detect by eye are easier to see, plus they are not done yet. If I find any to be intolerably asymmetrical while working on them I will make the necessary corrections before reaching final geometry.
Which will look something like this, starting as thin as possible at the heel, and keeping it for the whole blade, only increasing slightly at the tip for strength.
Here's some of the later stage prep and a bit of what's on deck. I'm hoping to have some near finish stage pics of two that are spoken. I still have LOTS of irregularities to clean up. But most of the fine work will be done with the dremel and then by hand sanding.
There will be slight variations in thickness due to scales starting at either 1/4" or 3/16". I am finding both are quite well suited to be used, and it only depends on just where you want your center of gravity. Both feel very light. One so far is slated to have texture, so that's on the to do list for tomorrow. I'm looking forward to texturing suretouch again. The rubber in it sort of cleans the drum as I grind, and I get better life from it than if I were grinding Micarta or Wood.
So the plan from there is to finish up all the Suretouch units, 22 in total, and by then Jason and I will have an idea of the configuration of the last few.
Thanks Josh I really like how they are shaping up as well. Mean slcets from heel to tip even without a refined edge yet.
Next step clean up and refinement but that will start tomorrow. I'm going to play soccer tonight.
