What's the strongest a fixed blade can be without weighing too much?
Pretty frickin' strong IMHO; not sure what unit of measurement would be used to state the actual value though...
I have a custom with a 1/2" thick, almost full flat ground blade in A8 modified tool steel; it only weighs 55 ounces and is crazy strong. :thumbup:![]()
ONLY 55oz?!I think that's more than my preferred hiking blade, axe and folding saw combined!
Bet it's a freakin' blast to destroy things with, though.
LOL, it has a 14" blade and yeah; it's kinda heavy for anything except car camping.![]()
Lots of fun for wrecking stuff though.
If you are up at 4 am thinking of topics like this, do yourself a favor and buy one of these and be done with it...
Well...we are all not from planet Craypton like you, are we?
But, you take a thick, strong/tough steel, eliminate stress risers, dont put holes in it...and it becomes less likely to break.
Take the same design, give it a greater cross sectional area (for example, by making it thicker), and it becomes even less likely to break.
Of course that increase in cross sectional area means more metal, and more weight. You could go on without upper limits.
Now where this "weighing too much" limit that the OP proposes is...who knows? (He may have the strength of 10 Crayptonians!) So the question becomes meaningless.
Unless the OP clarifies. Which everyone has been asking for since the thread started.
And what if we even had to...gulp....consider cost? Tough, lite, and cost effective. Can we have it all?
I think one undefined variable at a time (in this case "weighing too much") is enough for me!
Steel is weakest where is cross sectional area is smallest. Bigger cross sectional area=stronger.
Not sure what your question means either.![]()
Ummm, knives break at the fulcrum because that's how physics works. Tip broke? Probably because it was used to pry, placed the fulcrum at the tip. Knife broke around the ricasso? Probably got batoned with a caveman club, placing the fulcrum at the ricasso.
Material weakness obviously adds to this, but usage and physics are as, if not more, important in determining where a knife will break.
Apologies, the website didn't work last night, and I'm still getting the timeout error whenever I post more than one line.
Still can't post anything but a single line.
Did those knives fail because of the specified flaws or because of the way they were being used at the time? If the concept is to eliminate any flaw (in design or execution) or any flaw which could cause failure under any usage, I believe we have an exercise in futility. Just my .02.
