Just an FYI, isopropanol(rubbing alcohol) will work better than ethanol.actually, this is a great idea. I'll try grain alcohol.
why's that? I just figured I could get in the habit of keeping a multi-functional, consumable item on hand.Just an FYI, isopropanol(rubbing alcohol) will work better than ethanol.
It has a different chemical structure. It will also damage things like varnish more readily than ethanol.why's that? I just figured I could get in the habit of keeping a multi-functional, consumable item on hand.
ETA.... OHHHHHH... because it has rubbing in the name...![]()
This method works best with spit. Don’t try it in front of other people though. They look at you funny. Especially if you offer to cut their food afterword.
another recommendation for the ol' spit-n-rub?This method works best with spit. Don’t try it in front of other people though. They look at you funny. Especially if you offer to cut their food afterword.
Rubbing alcohol works for me .
Hand sanitizer.
I carry a little pocket size bottle of Purrell on me, and it's mostly just jelled alcohol. I use a bit on a tissue or paper towel and it takes the glue right off.
Hand sanitizer. Alcohol in a gel that sticks on the blade and soaks into the gunk.
Alcohol
At work, 98% isopropyl alcohol and a piece of toilet paper.
I use isopropyl alcohol and it works great for dissolving and removing glue.
Little, sterile, individually packaged alcohol wipes.
Nope. Been practicin’ for a long time. My method cannot be improved.another recommendation for the ol' spit-n-rub?
As I don’t oil the blades on my carbon steel knives to begin with, I wonder if this will matter.Just remember: if you wipe your blade with alcohol, it will strip the oil from it. So if you do this a lot then you may want to consider re-oiling your knife afterwards. Not a big deal if your knife is stainless, but still a possible issue if it's a folder.
In fact forget the knife,actually, this is a great idea. I'll try grain alcohol.
FYI rubbing alcohol is ethanol with a bittering agent added to it. Methanol which has a slightly different chemical and is poisonous to humans structure is usually part of the bittering agentIt has a different chemical structure. It will also damage things like varnish more readily than ethanol.
But you would have to weigh the pro's and con's of better cleaner but will kill you if you drink it vs if you drink enough grain alcohol you won't care as much whether there is still some crap on your knife.
I just did a quick search and apparently rubbing alcohol can be either isopropanol or ethanol, but the ones I have seen are isopropanol. They generally add the bad tasting additive(denaturing) to most commercial grade alcohol that is not for consumption.FYI rubbing alcohol is ethanol with a bittering agent added to it. Methanol which has a slightly different chemical and is poisonous to humans structure is usually part of the bittering agent
As some others have said, many of the chemicals here will strip off oil. Unless a true stainless steel or a carbon steel with a good patina, you will want to apply an oil or other rust preventative. Personally I use rubbing alcohol because I usually have it around in some form or another.
