"Survival" knife is a very vague marketing term, usually to push an over engineered, over built product on a bunch of Robinson Crusoe wanna-be's.
Since you are 12 I'll gonna tell you what the pros know and understand.
Straight fact is ANY knife becomes a survival knife if you are lucky enough to have it with you at the time you get into an emergency situation. It is all in how you utilize it in the given situation.
In the "typical" survival situation, you are presumed to be lost in the outdoors somewhere. You have 3 priority concerns Water, Shelter, and Food. Food is always last of the priorities because you can go for weeks without it. With water, you'll only last at best a week - but you will be incapacitated well before that. If you are in the desert, you may only last a day or two without water. If you find yourself caught in a blizzard outside, shelter is your first concern because it will kill you the fastest. You need to find or create shelter and a fire fast. If you are in the desert, water is you top priority, but get under some shade while you try and figure out how to find or save water.
The big thing is learn the skills and the mindset to survive. Learn how to build a fire, what you can use for shelter, or collect water. You should be able to do all of that without a knife if you have to. Those who can remain calm and creative in a survival situation are the ones that get out of it alive.
As to the knife, my advice is to save the majority of your money now, and get a inexpensive, quality knife like a Mora Companion. It will cost you about $20 tops. Then learn how to safely use it, and how to take care of it. Learn how to sharpen it freehand. Use that perfectly capable knife to help you learn the skills you would need in a survival situation. Use it to quickly and effectively build a fire. That means collecting and processing tinder, and kindling. Knife will help you get it ready, but it won't tell you what to look for or where to find wood or other fuel that is dry and will accept a flame. Again, knowledge is more important. Use your knife to make a fuzz stick or two so the fire catches quickly and well. Learn how to use that knife with flint or ferro rod to build a fire without matches. (other rocks will cause sparks besides flint- learn them) No rocks around to create a spark? You're gonna need that knife to build a fire bow or if lacking a cord for the bow part, make a "fire drill" and spin it in your hands to create the friction needed to make an ember and nurse it into a flame. None of this is easy, particularly the first time you try it. Learn it now so you can do it when you need to.
A skilled man with a butter knife has a better chance than the clueless guy with a Loveless or Randall. knife. If you just buy a "survival" knife and fail to have the knowledge and skills to actually use and apply it when needed - well - you can easily end up being just another dead greenhorn who had a really nice looking knife with him when they finally found him dead.
