- Mar 8, 2008
This raises two questions to a user. What is a good blade geometry? And how can the consumer achieve it?
An article in an old Irish agricultural journal discussing axes phrased it something along the lines of "edges of cutting tools should generally be as thin as is consistent with requisite strength", and that summarizes things quite nicely in my opinion.
One need simply identify what the tool needs to be capable of withstanding, and select a geometry as thin as the given steel and heat treatment are able to support in use. Of course, steel and heat treatment play into what the practical minimum dimensions are, and the skill of the user and context of use determine the kind of forces it has to be able to withstand. You just keep on asking "what determines _____?" and keep walking it back until you get down to the roots guiding the design. And good design is generally an iterative process because altering one variable impacts several others at once, so you just have to keep going around and around until everything is optimized relative to everything else.
