my Craftsman is looking like it might rank pretty well then. It is
thin, light, curved. There was some play in the end cap. I took it
apart and something had made a nest- maybe a mud dauber? There seems
to be a sliver off of one end, but the rest looks like new so I hope
cleaning and re-assembling and filling that sliver will make it
tight.
The blade is a new mark: N or N D
On snath geometry, since you have not already done it, here is my shot
at it:
Assuming that the problem to be solved in getting the blade to lie flat:
4 parameters that can be set are:
1) the length of the snath (at infinity, the blade will sit parallel to the mowing plane).
This has a price in terms of weight and loss of mechanical advantage.
The loss of mechanical advantage from the longer lever arm to the resisting grass would require
a) more human strength
b) faces 2 constraints at the point where
i) the nibs could not be made tight enough to resist slippage against the force
ii) the snath breaks.
These constraints could both be slackened by making the snath thicker, which would add
to weight.
2) the setting angle of the tang.
This adds cost if done at the forge and may compromise strength if accommodated to a
straight snath? Either blades would have to be in sizes, like shoes, or they would have to
be set at a blacksmith after purchase. In the 1850's blacksmiths were pretty common.
Maybe it would have been like having clothing tailored today.
3) the drop of the snath from the lower hand.
i) Square profile would be constrained by strength of wood and diameter of trees.
ii) Multiple pieces would introduce cost and weakness at joints.
iii) Using a round profile puts the constraint at the ability to bend wood, which
you have documented.
4) Diameter of the snath.
The wood has to be a certain diameter to resist the forces put on it
by the blade. These are governed by the length of the blade, the hafting angel
of the scythe, the type of material being cut, the weight of the blade, and how
the mounting hardware distributes the forces.
sub-problem: engineer mounting hardware to minimize strain on wood subject to weight.
subproblem:
Hafting angle might be like gears on a bike, letting you trade off between strength
and speed. Is there an optimal angle of attack for the cut against the plant? Is this
a function of blade sharpness? Blade thickness? This will affect the length of the blade.
Longer blade allows a more acute angle of attack for the same sized swath/speed
at the cost of power. The cutting friction is a function of the surface area of the swath,
so long blades pay a price in weight for angle of attack. This must substitute for sharpness
or thinness? So a super long blade should cut better assuming we reach maximum razor
sharpness? The grain cradle seems not to have to reach the ground, and has the longest
blade length. The fancy handle curves appear to let you open up your stroke wider. It is
a shorter lever, so you can put more force at the end.
The diameter of the wood increases the difficulty of bending and
increases weight. Greater taper allows more bend, but at the price of
nib slippage. Greater taper reduces nib adjustability before reworking
the nib loop is needed. The points on the snath that need strength are the
end and the middle nib. The middle nib diameter is solved by the lever
length and the force at the end of the snath and subject to the
constraint of nib slippage if it is too narrow.
I don't think they had the mathematics to do this until the 20th century.
Assuming they got the math right, the things to look for in a snath will be
maximum bend. This will call upon an optimal wood- that which can bend
the most while being strong and not flexing under use. Are the material
properties of wood such that the the problem reaches the optimal
solution point?
