- Mar 8, 2008
I would class those conditions as good![]()
You can't clearly see just how bumpy the ground is there. Depth never really shows up on camera, and it's a constant up-and-down in that section, combined with lots of big ol' knotted grass clumps. The section at the very beginning is more forgiving but as soon as I move past the space between the barn and the shed it turns into mowing hell.
but those sudden stops when you hit something are why I quit using the level rotating arc stroke for anything but cutting smooth lawn type stuff! It can be a small sapling, a rock the edge of a dip or an 8" thick clump of mature orchard grass, whatever resist beyond the blades momentum will stop it and transfer shock back to the tool and, worse, the user. With a steeper pitched and crowned blade, a sweeping motion across the swath is less likely to have an obstruction stop the blade, and if it does, the shock is transferred back to the arms and shoulders mainly, not a twisted spinal column! Of course, the finished appearance is somewhat less smooth and even and the width of the swath reduced, but the difference in harvested grass/hay is negligible if at all.
Just my observations, but important to me because I think scythes are most useful in places most unlike the flat, smooth fields we most often see them used in on YouTube.
If I were just mowing for the sake of the grass as a crop then I'd fully agree with you. However, this area was being mowed for foot traffic, and so a lower cut was needed. I only used sweeping cuts in areas where I was less likely to be stopped up, and for the sake of taking as much as I could per stroke without straining myself. You'll notice how I only use sweeping cuts at two regions in the video, and the rest is shorter, more abrupt strokes, many of which are at a lifted angle. This is a combination of using a long blade to get into little dips and valleys and also taking targeted shots at clumps since they would interrupt a longer stroke. I actually used a lot of sawing cuts, as well, when trimming up along edges of obstacles.
